If your monitor is only monitor just connect it with vga cable connector at the back of the monitor then goes through at the back of pc unit. however, if the monitor;TV/Monitor you need to use the supplied remote of the monitor set it on pc display same procedure in connecting monitor to pc unit.
Depends on the windows program if you are running windows and what version, i can tell you what f key to hold when it starts, sometimes entering admin as the password under default works if not need to either hold down f2 or f9 sometimes f8 just depends, they have to be held down while powering as soon as the startup screen apears go into the settings and turn off start up password set it to admin.
THE pC IS DEAD OR IS In sleep mode (flashing LED means that)
so start post why is my PC dead and tell what PC it is makers name an model.
hint: desktops PC has 6 sides one of them has service tag label and tells what PC this is.
Q1, PC FANS MUST SPIN DO THEY? IF NOTHOLD POWER BUTTON ON PC , DEPRESSED FOR 10 SECONDS AND RELEASE.
Please turn off the computer, start hitting F8 at the start-up and then
choose last known good configuration. If this does not work, choose Safe
mode options. If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery. If not working, please tell me what error message you get on the screen.
Right clcik on the desk top screen go to properties and click on properties and clcik om the resalution you want and 32 bit then click ok, once you do that if you like that setting click ok and close window and your good to go, if you still have trouble please post here.
please tell us what operating suystem are u using
and can lu tell me in the system properties what is the theme properties set to if you can set it to current theme and see what happenes ok best regards mike
Just try resetting the BIOS and check if it works.
You need to access BIOS screen and most of the computers has F% key is assigned for Loading the Dedault Settings. After F5 key you need to press the F10 key to save the settings and exit from the BIOS.
HELLO. TELL ME THE COMPUTER YOU HAVE ON THE SAME WIRELESS NETWORK.! AS YOUR NEW LAP TOP.!!! IS IT A HOME TOWER.? OR DESK TOP.? OR A NOTHER LAP TOP.? AND TELL ME WHO IS THE ROUTER MADE BUY.? WHO IS THE SERVICE THAT IT CONECT'S TO.? TELL THESE THING OK.?AND WE WILL GO FROM THERE. OK.!!!
