Ok, my boss is out of town and I can't call her. Someone tried to sent us a fax but when they did The screen shows "Out of memory - Erase message". How exactly do I do that?
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
Usually, faxes are
temporarily sent to the printer's memory when one of the cartridges' ink level
is not substantial for printing. You are advised to replace the cartridge/s, *without
navigating away from the message "fax sent to memory", by opening
the printer cover and replacing the low-ink cartridge/s. After the new
cartridge/s is installed, close the printer cover and press OK button to let
printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Usually, faxes are
