Inspiron 9200 is not being recognized or playing any cd/dvd's.
If the drive is showing an error (or is missing) in device manager, do the following:
Start Registry Editor (Start, Run and type in regedit then click O.K)
Locate the UpperFilters value under the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the Edit menu, click Delete, and then click OK.
Locate the LowerFilters value under the same key in the registry:
Quit Registry Editor.
Click start control panel administrive tools computer
management device manager scroll to cd/dvd rom drives right click properties
then properties again then tick enable cd
digital cd audio for this cd rom device also scroll to dvd regions select
the no _ for your specific area
If this does not fix the
problem you might try
you might have to
physically unplug the leads for this cd-rom then plug them back in this
should activate the found new hardware wizard
you might have to uninstall
then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this
device
click start control panel
admistrive tools,computer management,device manager scroll down cd dvd rom
drives right click you will see options to update driver,roll back
driver,or
select properties general
troubleshoot, select driver click to reinstall drivers click update
driver or uninstall then reinstall
hope this helps
Click on
Start, Run, and type regedit and press
Enter
Click on the plus signs (+)
next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the
following names in the right hand column.
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
If any of the above keys shown in step
4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and
check to see if your CD or DVD drives have returned. You may also want to open
Device Manager and verify that the yellow exclamation and error code on the CD
or DVD drive is gone.
hope this helps
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
