FixYa.com
NEC ND-6500A DVD±RW Dual Layer Burner
All Products > NEC > CD and DVD Burners
Problems with NEC ND-6500A DVD±RW Dual Layer Burner?
Troubleshooting and Support
Solved Problems for NEC ND-6500A DVD±RW Dual Layer Burner RSS Feed Post a New Problem
Dual layer?
how do I tell if my NEC DVD +- RW ND-6650A will burn dual layer dvd's-I can't seem to find the format in my...
1 Solution
NEC ND-6500A Cant burn DVD-R
I use NEC ND-6500A drive on my Dell Inspiron 700m and use Sonic to burn disks. I can burn cds with no issues. But when I...
3 Solutions
CD/DVD won't eject, won't play, Device...
I have a Dell Inspiron E1505. The DVD+RW that came with the computer is a NEC DVD+TW ND-6650A. The computer is about 8...
1 Solution
Replacement of failed DVD laser
My DVD will not load DVD's but will run CD's and audio and data. I was informed that it was most likley a failed DVD...
1 Solution
Changes regions
Hi, Can you help me to change regions as my dvd player is on region 1 and i would like it to be on region 4. I didnt no...
1 Solution
Cannot read dvds
NEC ND 6500A DVD burner . this is the 2nd drive i have had that develops fault will only read cds
2 Solutions
SONY DW56A
HI, I HAVE A SONY VAIO VGN A417S ANY BODY KNOW A RELIABLE DVD RW DRIVE THAT WILL BE COMPATIBLE WITH MY MACHINE?? NOT THE...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for NEC ND-6500A DVD±RW Dual Layer Burner RSS Feed Post a New Problem
Dell Inspiron 9300
When I insert a new DVD-R I get the error message D:\ is not accessible Incorrect Function
Post a Solution
no sound
There is no sound when I play a dvd. The sound is fine if I play a cd.
Post a Solution
Can't read CDs but Can
Can't read CDs but Can read DVDs
Post a Solution
Not burning anything dvd?
I installed a NEC ND-6500A DVD±RW Dual Layer on my inspirion 5100. It will do anything perfect with cd cd-r cd-rw...
Post a Solution
Each time I record music on to disc the first three tracks are fine, then the next three or four crackle and skip. After...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC
Burner TypeDVD±RW Dual Layer
Storage TypeDisk Library
ReWrite Speed16x (CD-RW), 4x (DVD+RW), 4x (DVD-RW)
Enclosure TypeInternal
Read Speed24x (CD), 8x (DVD)
Write Speed24x (CD), 8x (DVD+R), 8x (DVD-R), 2.4x (DVD+R DL)
Technical Features
InterfaceIDE / EIDE
Tray Qty.1
Buffer Size2 MB
Supported CD FormatsCD Text · CD-Extra · Photo-CD · Video-CD · CD Audio · CD-Bridge
Access Time CD130 ms
Supported DVD FormatsDVD-ROM · DVD-Video
Access Time DVD160 ms
Supported Media Writing StandardsDVD-RW · CD-R · CD-RW · DVD-R · DVD+R · DVD+RW · DVD+R DL (Double Layer)
Recording CD ModesMulti-Session · Track-at-once · Disk-at-once · Packet Write · Session-at-once
Recording DVD ModesRandom Access Write · Sequential Write
Other Features
FeaturesBuffer Underrun Proof · Emergency Disk Eject Hole
MountingHorizontal · Vertical
System Requirements
Operating SystemMicrosoft Windows Millennium Edition · Microsoft Windows XP · Microsoft Windows 98 Second Edition · Microsoft Windows 2000
Dimensions
Depth4.99 in.
Height.49 in.
Width5.03 in.
Weight.41 lb.
NEC Contact Information
Main support number1-800-338-9549
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
