Air Flow issue sounds like. Is there go air flow at the rear of unit? Maytags of this style usually wear out blower wheels which moves the air through the unit, check the blower wheel see if you can move it without turning the drum, This is of course with the front panel off, The blower wheel is item #4 in the diagram and it's locate just behind the front panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/william_e43a8a4d83a5f604
Disconnect the power cord from the electrical outlet before servicing the Westinghouse dryer.
Insert the putty knife into the gap above the front panel and below the top panel. Lift the putty knife handle up to unfasten the internal locking clips.
Lift the top panel from the dryer cabinet. Rest the panel on the wall behind the dryer.
Remove the two screws on the top border of the front panel. Lift the front panel straight up to unhook it from the dryer cabinet. Unplug the connector leading into the front panel. Set the front panel aside.
Move the idler pulley arm toward the front of the dryer cabinet to loosen the belt. Remove the belt from the drum and pulleys.
Lift the drum out of the dryer cabinet.
Disconnect the electrical plugs leading into the heating element. Unfasten the screws securing the element to the inside of the cabinet. Lift the element out of the cabinet.
Place the new heating element inside the dryer. Connect the screws holding the element to the cabinet. Plug the electrical connectors into the element.
Reposition the front panel. Plug the door switch connector into its socket on the front panel. Press the panel straight down into the base. Reinstall the screws along the top of the panel.
Lower the top panel onto the dryer. Press down on the panel to lock it into place
