Question about Whirlpool LGR3624JQ Gas Dryer
DRYER HEATS ,BUT DOESN'T TURN
IRINAL
HI,
MY DRYER HAS HEAT BUT DOESN'T TURN
I OPENED THE DRYER ,
MY QUESTION IS --WERE IS THE BELT SUPPOSE TO BE ?AROUND THE DRUM OR I NEED TO OPEN BACK PANEL?
THANK YOU
Posted by IRINAL on
Gerald Griffin
  • 248 Answers
FIRST UNPLUG UNIT!!
Remove 2 screws by filter area on main top.
Grab back of dryer and pull top forward while holding dryer in place with knees. Do this to pop up top on front left then front right. Remove 2 screws holding front panel 2 side panels. They are at top front of side panels, inside.
Pull front panel out at top and pull up to remove front panel. Put belt around drum with grooved side toward drum.
Posted on Nov 11, 2007
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
My dryer heats up, but turntable doesn't turn...
it could be the motor or just the belt. back of dryer needs to be opened there should be a large belt that wraps around the whole drum, also theres a belt tensioner that also could be the problem if belt is too loose.
Dec 23, 2011 | Dryers
DRYER WILL NOT TURN ON AT ALL
Hi.
If the dryer does not start and does not heat check thermal fuse and door latch. Both parts can be tested reading impedance with a multimeter.
If the dryer starts and heats up but the basket does not turn, check the motor and the belt. In that case you probably have a broken belt.
Regards.
Ginko
Dec 15, 2011 | Maytag PYE2300AY Electric Dryer
My dryer still heats but doesn't turn, can it be fixed?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 07, 2011 | Dryers
Dryer heats OK when turned on but the timer never moves and the dryer doesn't turn itself off......
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./,./'
Jul 13, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My kenmore electric dryer turns on and heats but the drum doesn't turn?
that would be a broken belt, or the motor, I say belt. You will need to open the top of the dryer and look in the middle of the drum for a belt, which is not there I am sure, here are some websites,Tim:
how to change belt:
http://www.ehow.com/how_4814455_change-kenmore-dryer-belt.html
belt routing Kenmore is same as Whirlpool:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.htm
May 23, 2011 | Kenmore Dryers
Gas dryer initially heats then heating stops
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Jan 08, 2009 | GE DBSR453EBWW Electric Dryer
Whirlpool LGR3624JQ Gas Dryer Logo
155 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Ned Halaweh
Ned Halaweh
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
