Its a fuser code. To reset it the code and to get it work again. Follow these steps:1) Turn the main power off ( the switch behind the toner door )2) Hold down the Utility button while you turn the machine back on. Jul 12, 2017
PrintCopy .info
https://printcopy.info > code=C3423
Code: C3423 · Description: Fusing heaters trouble (pressurizing side) · Remedy: 1 Check the fusing unit for correct installation (whether it is secured in ...
Jun. 26, 2017 - Hi all I have the C0206 & C0208 when connecting the PC-410 (twin cassette) ... jonbonse is offline ... Konica C224 error C0206 & C0208 ...
Code: C0208; Description: Tray 4 Elevator Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper lift up ...
Missing: Mita. ‎' Must include: Mita.
https://printcopy.info > model=bizhub+Pro+950
Code: C-0003 · Description: Main body drive serial input abnormality 3. Within a specified period of time after the power ON ACK, a serial data is not received ...
the bizhub 222 typically does not not throw this error code this is an error code is for one of the older konicas and is a toner density error code check developer/ developer unit if this is a bizhub 222 the toner density error code would be c2557
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code. In Bizhub C350 that code means: C12C0: Hard disk recognition error You have the following options: - reinstall the hard disk - change hard disk or as a last chance change PWB-MFP
