Question about Konica Minolta Bizhub C 353, Bizhub Color,bizhub C 253,konica,bizhub C 450,c 550
Konica minolta bizhub c450 error code c- d370
Error code 370
Posted by Abel Sampa on
Arsalan khan
    New Friend:
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
Posted on May 16, 2015
Fuji Frontier 370 error w2108 how to fix it
ERROR E-2415, 2418, 2416, 2411 FOR FUJI FRONTIER 370
Jan 08, 2017 | Fuji Cameras
Error 003-370
"master code detect error" most likely a software problem but could be a hardware problem, go in this order...
Change out the RAM, replace hard drive or the ESS PWB
Aug 13, 2014 | OKI B6300n Printer
2155cn printer giving error #006-370 what should I do
Power off the printer and turn it on again with the big button held down (the one with the tick on it).
This seems to clear the error and allow printing but won't fix the fault itself.
Feb 17, 2014 | Dell 2150cn / 2150cdn / 2155cn / 2155cdn...
We have konica minolta c350 and getting error code 370. plz help us... thanks
code is incorrect c-XXXX c the by 4 letter/number combinations
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 26, 2012 | Minolta C350 Color Printer/Scanner/Copier
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
Dell 3130cn gone down with repeating 016-370 Error...
This type of error code implies that you need to restart the printer again. However, do check to see if toner cartridges are seated in the proper position. Also ensure that they have been locked in. This is an error commonly associated with the Dell 3100cn laser printer. Please let me know the results.
Jun 28, 2010 | Dell 3100cn Laser Printer
Docuprint DP211 has error 006-370
006-370
Restart Printer
Contact Support
MessageReturns
Condensation may have occurred inside  the printer.
Do not use the printer for more than one hour.
If this does not solve the problem, contact Dell.
See "Contacting Dell" in the Owner's Manual.
Jun 04, 2009 | Office Equipment & Supplies
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Sep 04, 2008 | Xerox Office Equipment & Supplies
Konica Minolta Bizhub C 353, Bizhub Color,bizhub C 253,konica,bizhub C 450,c 550 Logo
857 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
