Snails are vegetarians, Depending on the kind of snail it is. If it is a land snail.... tomato, lettuce, etc. If it is a aquatic snail, get some sea weed, and other types of green stuff from the local river. (let it soak in clean water)
Egg Shells
Egg shells not only deter slugs and snails, they also act as a fertilizer. They are especially beneficial to fast growing plants like fennel, peppers, green beans and tomatoes. They deter slugs and snails in much the same way as DE.
How to use:
Rinse shells thoroughly and air dry
Place in bag and crush
Spread crushed shells around bases of plants
Make a Beer Trap
This method seems to be favoured by people I've talked to and in books I've read. The critters fall into the beer and drown - cruel, I know, but it's them or your plants.
How to use:
Bury a recycled pie plate, plastic container in soil so that the brim is level with the soil. Some people just place a saucer in their gardens. Fill with beer to near to top of container. Check trap daily to dispose of pests and refill with beer.
Land snails secrete mucus to facilitate locomotion and reduce the friction against the ground.
Snails try to get a diet that is full of calcium to keep their shells thick and healthy.
Land snails have microscopic teeth! They are contained in a structure called the radula and that is composed of rows of them.
The "cone snails" a family of sea snails is venomous and some of them are fatal to humans!
There are around 600 different species in the family of "cone snails".
There are around 30 humans killed by cone snails, that have been registered.
The sea snails breathe with gills, the land snails breathe with lungs while some species of freshwater snails breathe with lungs and others with gills.
Several species of land snails are used in the cuisine of several countries and they are considered a delicacy.
Land snails are mainly herbivorous, which means they eat plant life. There are a few snails that are carnivores, but chances are that your snail in not. Snails love to eat just about anything you would put in a garden salad. My recommendation is to start with some romaine, green leaf or even ice burg lettuce. Snails tend to like the softest and wettest part of the plant. If you have an herb garden that produces far more herbs than you need then try picking the newest leaves off of some of your herbs to see if they like them. Apples and carrots can also be a favorite of your pet snail. The key to their diet is to see what grows naturally around the area where you found your snail and bring that to them. During the winter you will have to rely heavily on the produce in your refrigerator to keep them well feed. Remember if the snail is eating all the food you gave him or her then you need to leave more out for them. Slightly rotten food is just fine. They are not terribly picky as long as you give them a food they enjoy.
One last tip: During the spring and fall when your grass is the greenest make sure to cut a big handful of grass for your snail to eat. Both land and the common garden snail love grass and most leaves.
What do water snails eat?
The common water snail is predominately an herbivore. Water snail mainly feed on the algae that will naturally grow on the inside of your fish tank or fish bowl. If you are putting a new snail in a fish tank then watch out! If you have any vegetation in the tank that you are fond of then do not put your snail in the tank. Larger snails can wipe out all plant life in just a few days.
Snails also eat algae along with the microscopic creatures that naturally live in a healthy ecosystem. In most cases you will have to supplement their diet with fish food. Along with fish food cubed up apples and carrots are a favorite. It will take a day or two for the apple or carrot to sink to the bottom. Once on the bottom and partially decayed your pet snails will thank you for the treat.
Tip: If you have more than one snail they are going to reproduce. To help minimize the number of snails in your aquarium you can simply cut back on the about of food you feed your little guys.
This sounds like you have most of your memory used up. what yo need to do is,
Click-
Start
Control panel
Performance and maintenance
Free up space on your hard disk
Tick all the boxes
Ok
If this dors not work you may need defrag your laptop.
OR maybe you have to many progams on your laptop, so you may need to delete some that you dont use.
Your computer is running for sh-- because you probably have too many items starting up at boot time and running in the back ground. You have to go into your msconfig files and services,.msc files to turn off unnecessary operations. And virus programs are notorious for using up memory resources and turning computer into a snail. If you have one, get rid of it and stay off the p-rn sites.
It is not the cpu or power supply responsible for the issue. It is the user at fault for overloading the machine's resources. And a new computer will get just as bad if you continue to employ the same habits as you have with this unit.
if you have a multimetter mesure the value from the ground to positiv polarity of the starter-value must by lower 30 ohm.if there is good please check mechanical coil starter contacts and the batery. try to recharge the battery .if doesn,t work propertly the last solutions it,s to change the schaft bettw. starter and engine.be sure to the moment when you press bettw. (screw) starter -engine body.
It might not be a problem with your setup but with your provider. Give them a call and relate your concern. If the provider informs you that nothing is wrong then post back and we can go through the checkup process and determine if anything has changed or need modifications to make your connection as fast if not better as before.
Good luck and kind regards.
