SOURCE: jenn air 32 in. 4 burner gas grill
HAVE YOU TRIED THE ORIIGONAL TANK? SOME COMPANIES HAVE SPECIFIC TOLERANCES FOR FITTINGS THAT MAY NOT WORK W/ OTHER ITEMS.
SOURCE: jenn air grill
You should test the wiring to see if there is any short that is causing the overheating.
If one knob only is getting hot, then the knob is probably faulty and need to be replaced.
I the all knobs are overheating because of heat coming from the grill, then is a bad heat insulation problem, better to call the service number listed on the owner manual and discuss the problem with Jenn Air in this case.
Here you find replacement parts for your model, in case you need to replace a knob.
SOURCE: Jenn Air lp grill won't light with the ignitor button
I just finished cleaning our starter on our jenn air. Over time, corrosion, rust and battery acid builds up on both the coils on the lid (positive side) as well as in the battery chamber and negative tip inside the chamber. I used sand paper and sanded the coils in the cap and the chamber. The coils need direct connection to the battery to create the charge. There are no instructions on this that I was able to find. I figured it out after about 3 hours of fussing with it. It worked immediately once I placed the battery back in. You may also need to clean the electrode tips near the burner. I used a q-tip. Hope this helps.
SOURCE: How do you replace burners on Jenn-air 720-0337
First, remove the grill grates, then the flame tamers to access the burners. As you face the grill, carefully lift up the end of the burner farthest from you (It may or may not have a cotter pin holding it in. If it does, remove the cotter pin with a pair of needle nose pliers). As you lift it up, it should pull away from the burner orifice (inside the control panel). And that's all there is to it.To reinstall the burner, do everything in reverse. But, there is no need to replace the cotter pin. It was there for shipping purposes.
Hope this helped you. Please let me know. Happy Grilling!!
SOURCE: Do Jenn-Air have recommended suppliers?
Appliance Factory Parts http://www.appliancefactoryparts.com/ is a good place to start. They carry parts for just about all makes and model grills. If you can't find what you need under Jenn Air, try looking under NEX Grill. Actually, they are the manufacturer of the Jenn Air Gas Grill.
Hope this helps you. Please let me know. Happy Grilling.
