n
nwokafor ebele Posted on Oct 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Convert 8.1cps to mm2/s using a density of 1017.72
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on Oct 11, 2013
k24674
Level 3:
Answers
8093
Questions
0
Helped
4675934
Points
21596
1helpful
I NEED TO CONVERT 400 TONS TO CUBIC METRES , USING A BULKING FACTOR OF 1.600
First you need to know the density of that particular rock. Then, find its volume by:
Volume = Mass (400tons) / Density
After that, multiply by the Bulk Factor.
Bulk factor of 1.6 means that when you dig 1 cubic metre of rock
it bulks to 1.6 cubic metres in the lorries.
Google calculator gives 1US ton = 907.185 kg
If your ton is US ton, then 400ton = 400*0.907185 or 362.874 kg
Example: Sandstone (porous): Density = 2.5 kg/m3
(ref. https://www.nrc.gov/docs/ML0807/ML080700314.pdf)
Uncut 400 us tons of this Sandstone then has a volume of 362.874kg / 2.5kg/m3, giving 145.15 m3
Now get your cut volume by multiplying by the bulk factor.
This gives: 145.15 m3 x 1.6 = 232.24 m3
Hope this is what you wanted.
If the answer is 363.81, how many f/mm2 would that be? if the answer is 113.8, how many f/mm2 would that be? If the answer is 489.49, how many f/mm2 would that be? if the answer is 67.52, how many...
This looks like part of a homework question. What is the unit f/mm2? Farads per square millimeter? What is the unit that goes with the numbers? Is it Farads? In that case, you would need to know the area to calculate the capacitance per unit area.
Milliliters to milligrams
Converting MG to ML will vary depending upon the density. It is not possible to know how many MG equal ML because milligrams are used to measure weight and milliliters are used to measure volume. You would need to know the density of the item that is being measured...
2answers
Convert mg to ml
Milligram is a unit of mass (or weight), milliliter is a unit of volume. Any conversion between them depends on the density.
62.5 milligrams of water occupies 62.5 milliliters. 62.5 milligrams of gold occupies about 3.2 milliliters.
What is the convertion of 1000kgf/cm2 to N/mm2
98.07 N/mm^2
http://www.wolframalpha.com/input/?i=1000+kgf%2Fcm^2+to+N%2Fmm^2
3helpful
2answers
1 m2 = _____ mm2
1 m2 = 1.000.000 mm2 because 1 m = 1.000 mm.
If you feel helped RATE please !
900 mm2/sec is equal to how many centipoise
1 P[oise] = 1 g / ( cm * s ) is a unit used for dynamic viscosity.
1 St[okes] = 1 m² / s is used for kinematic viscosity.
To get the kinematic viscosity from dynamic viscosity, you need to divide the latter by the density of the liquid in question. You did not provide this value, so I cannot do the calculation for you, but you should be able to do your homework with this hint yourself. All you need to take care of is to adjust the scale factors later. 100 cP = 1 P, 1000000 mm² / s = 1 m² / s = 1 St.
3answers
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
3helpful
3answers
How to clean Density Sensor of Hp 3500 ?
Thank you for this info. I used your advice to fix my HP printer and it worked. By the way, great link to HP support parges on the www.partshere.com site. I was able to fix my printer and by the way purchased more printer parts and fusers. Thank you again!
k24674
ADMIN Andrew
ADMIN Andrew
