When power on this washer, only spin on 1 min, then power off.
Hi David Simpkins - Based on the symptoms you are describing, the washer may be experiencing a communication issue with the control board or faulty wiring. You may reprogram the washer by disconnecting the power to the unit up to two minutes by flipping the circuit breaker off and back on. If issue persists, I would recommend contacting a professional to proceed further.
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
