Where can you purchase Siemens parts in the USA? We've just begun our search for a drain pump for...
(More)
Where can you purchase Siemens parts in the USA? We've just begun our search for a drain pump for our WFXD5200UC UltraSense Washer. Thanks
Shortly after the warranty expired, our Siemens WFXD5201UC Front Load Washer began to stop...
(More)
Shortly after the warranty expired, our Siemens WFXD5201UC Front Load Washer began to stop mid-cycle. At first it was "occationally", now it is "usually". But, it is still random, and happens at odd times in the cycle. It most often stops with about 21-35 min remaining on the 59 min Regular cycle but will go as low as 1 min remaining. Occationally it will complete the cycle and beep but the clothes will still be soaking wet. The times I have caught it in the act, it is after the pump runs to drain the water, the drum doesn't turn to spin out the load. All the cycle indicator LEDs go off except the "Door Locked" indicator, no error codes show. Even the "Rinse and Spin" cycle will hang up. I've tried the "Quick Wash" cycle and others with the same results. Tried other spin selections... no difference My 1st thought was that there was some high speed spin contact for the motor that it wasn't recieving. I found the schematics and tore everything apart and nothing like that. The motor controller appears to be a VFD-like device that linked to the main controller with only a couple wires (some Comms protocall???). I would think if it was an issue with the main controller it would be more consistant? Thanks
this machine was flooded but water only reached half way up however power was on at the time....
(More)
this machine was flooded but water only reached half way up however power was on at the time. problem is an extremely long wash cycle. all cycles work fine and will finish but wash times exceed an hour. Q. how many circuit boards are there ? and does this sound like a timer problem. timer is integrated into the control board. any help from the crew? and if not could you pass this along to others to possibly come to a conclusion? Thanks , Tim
Is there supposed to to water in the pump catch of wfxd5200uc. I see a big white nut when I get this...
(More)
Is there supposed to to water in the pump catch of wfxd5200uc. I see a big white nut when I get this apart can someone explain this to me and how it works. I took the black cap off and now when I run the washer it leaks water out of the black cap.
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain...
written by jsrock516
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the ?F21? error code. ?F21? is a Long Drain error. If the drain...
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows...
This advice is for Kenmore & Whirlpool TOP LOADING DIRECT DRIVE type washing machines. This is NOT for older models equipped with a wig-wag...
This advice is for just about all Kenmore and Whirlpool model TOP LOADING washing machines. This is an easy repair that anyone with a little know-how...
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines. The first thing to do is...
Welcome to Action Appliance Repair. We have bee... Read More
Welcome to Action Appliance Repair. We have been serving the greater Hartford and Springfield area for over 40 years. We are dedicated to working around your busy schedule. Please call now to receive the $25.00 discount coupon available. We are family owned since 1961. Call now for your free ph
Washer and Dryer repair specialists.
Why hire som... Read More
Why hire someone else to fix your appliance when you can do it yourself? And we can help!
Download a step by step tutorial loaded with pics at www.shop.washermd.com
Our focus will always be to provide top-notch qua... Read More
Our focus will always be to provide top-notch quality service and customer satisfaction of repair services to our customers and partners on Warranty/non-Warranty Dimplex heaters, TV & Electronics, HVAC, Electricity, Home & Industrial Appliances, Sports & Exercise Equipment, Treadmills, Spas & Saunas, Office & Computer Peripherals.
