SOURCE: Panasonic Dp-190 Displays
Hi, your problem is comming from the exhaust fan ( fuser unit side ) It is probably defective but you can check to see if the connectors are plugged in properly. You can also check the LVPS connectors. If none of these works, your problem is going to be located in the LVPS or the engine PCB.
