1996 Dodge Caravan Logo
rjw59 Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I get code 51 on 1996 dodge caravan....fuel system lean---a lean air/fuel mixture has been indicated by an abnormally rich correction factor. The van runs fine when engine is cold but will sputter and won't accelerate sometimes when it is driven for a while. I drove it about 30miles this weekend and it ran fine. After about 30min of being turned off I started driving again and it started sputtering and died and I couldn't get it started again. The next morning it started right up and was running good. I'm afraid to drive it now for the fear of being stranded on the side of the road. It has been doing this for the past year but is now getting worse. I recently changed the fuel filter with no change....Now I,m wondering about the fuel pump. Any suggestions on what the problem could be.
Bill Boyd
Level 3:
Top Expert:
  • Dodge Master 53,816 Answers
  • Posted on Sep 23, 2013
Bill Boyd
Dodge Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950506
Points
172802
The code is telling you where the problem is. Try replacing the HO2S sensors as the cpu is having trouble keeping the air /fuel mixture within limits. Check the cat converter for cracks or blockages . Have a pressure test done on the fuel manifold to check for pump/filter and pressure regulator problems. Check the ambient air temp sensor and coolant temp sensor as they also affect the air/fuel mixture.
5 Related Answers
Anonymous
  • 21 Answers
  • Posted on Jan 07, 2009
SOURCE: 2004 dodge caravan 2.4 Hesitates during Acceleration and at idele
You should definitely replace the fuel filter though this probably won't fix your hesitation. It wouldn't hurt to replace the spark plugs this is usually the culprit on these engine. I have the same engine in a '99 caravan and found the for some reason the spark plugs on cylinder 3 and 4 loosen up after one year and cause a misfire between 45 and 50 mph under load (when mildly accelerating).
Anonymous
  • 61 Answers
  • Posted on Apr 22, 2009
SOURCE: 04 dodge intrepid sxt not picking up fuel, wont start
You may have to replace the fuel filter, the fuel pressure regulator or the fuel pump.
First I would check the fuel pressure and also check for leaks. If there are no leaks and the pressure is fine than your fuel injectors are probably clogged or you may have an ignition problem or even a compression problem.
If you don't have good pressure and there are no leaks I would first replace the fuel filter or the fuel pressure regulator. If problem still exists I would then check and replace the fuel pump.
If you need any help in any one of these procedures just post it and I will give you step by step instructions.
Anonymous
  • 6 Answers
  • Posted on May 26, 2009
SOURCE: 1993 Dodge shadow died while being driven, won't restart
try the transmision you may have to replace it
Anonymous
  • 1986 Answers
  • Posted on Aug 21, 2009
SOURCE: Van sputters still and worse then before
I would recommend having the TPS sensor checked as that is the first cause for rough idles and stalls...
Anonymous
  • 369 Answers
  • Posted on Feb 04, 2010
SOURCE: I have a 2002 caravan 3.3L engine light came on
the most propable cause is you have a vacume leak. Check all intake hoses for leaks and spray brake cleaner around intake gaskets if rpms change then you found a leak also clean your mass airflow sensor
1helpful
2006 dodge with 5.7 hemi my tester reads --system too rich bank2. when testing spark plugs,what does this mean.
I'm not sure what you mean by testing spark plugs. The diagnostic code defined as "system too rich, bank 2" indicates that the reading reported by the bank 2 cylinder bank (containing cylinders 2, 4, 6, and 8) is consistently reporting a rich exhaust mixture rather than a reading toggling between lean and rich. This might mean you have a fuel injector that is not providing the correct amount of fuel, a spark plug that is not properly burning the air/fuel mixture, an oxygen sensor issue, a wiring issue to the sensor, etc.
-Rod
1helpful
2000 dodge caravan code 0172 bank1
That is a fuel mixture code indicating it is too rich. You definitely have some fuel control problems with this car.
What is the code 171 mean on my dodge ram 1500
P0171 Chrysler - Fuel System Lean
Possible causes
- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection
Tech notes
If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
When is the code detected?
- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.)
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel Consumption
P0171 Chrysler Description
With the Air/Fuel Mixture Ratio Self-Learning Control, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The Engine Control Module (ECM) calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the Malfunction Indicator Light (MIL) (2 trip detection logic).
P0171 Chrysler Fuel System 1 1 Lean
What is code p017.2 for a 2002 dodge caravan
This is the closest I've come to the code you are looking for. I searched all Dodge codes and didn't see any with a "point 2" but I found code P0172. According to EngineCodes.com your fuel mixture is probably too rich. This is what the site had to say:
Possible Causes for this Code:
- Exhaust gas leaks
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waCcFhN
This code is detected when:
- The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.)
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waXE700
Possible symptoms:
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35waruoIU
P0172 Dodge Code Description:
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the ECM judges the condition as the fuel injection system malfunction and light up the MIL (2 trip detection logic).
Read more: http://engine-codes.com/p0172_dodge.html#ixzz35wbfFdyj
Hope this helps!
2helpful
2answers
Cod of 51 on grand cherokee 5,2 which o2 sensor is out of order
Well, code 51 means the O2 sensor is telling the computer the fuel mixture is lean. So the computer tries to make the mixture rich by opening the injectors longer. I doubt the sensor has failed, but rather your fuel pressure is low.
If the sensor has failed and pressure is normal, you should have black smoke coming out the exhaust pipe.
1helpful
I have code p0507 & p2187 on my 2004 Saab 93 the idle is rough
Combustion engines operate by burning an air/fuel mixture of about 14.7 to 1-14.7 parts air to 1 part fuel. When the air ratio goes below 14.7 parts, this is called a "rich" mixture. If the air rises above 14.7 parts, it is called a "lean" mixture.
Rich Mixture = Too much fuel, not enough air
Lean Mixture = Too much air, not enough fuel
To keep the engine running properly, the Engine Control Module measures the oxygen content in the exhaust with oxygen sensors and makes adjustments to the mixture by injecting more or less fuel.
P0507 Idle Control System RPM Higher Than Expected
P2187 System too lean at idle
Things to check:
1. MAF
2. Fuel pressure, fuel pump flow rate
Do you have cold air intake?
Run a fuel system cleaner first and reset software. Long Term Fuel Trim Additive. Max Value, Air/Fuel too Lean.
Fault symptom
Lamp
The engine may stop after starting, run unevenly and misfire or run
at high rpm.
On-board diagnosis
Type of
diagnosis:
Continuous
Enable criteria:
The engine has started and lambda control is active.An additive adaptation is
carried out.Cooling and intake air temperature 60°C.Fuel level at least
12%.
Fault criteria:
The additive adaptation factor is greater than 5.25%.
Diagnostic help
Diagnosis
regards:
Checking air/fuel ratio. With this DTC, the engine will be getting too much air or too little fuel.IMPORTANTA crankcase ventilation leak may be one reason as to why a DTC is set. Check crankcase ventilation function before starting regular troubleshooting.
Functions in the diagnostic
tool related to the fault:
Test value:
•O2S1 lambda
•Additive
Adaptation
•Short Term Fuel Trim
•Purge Adaptation
•Airmass Deviation
from Calculated
•Total Fuel Trim Here's a helpful link for you: http://repairpal.com/OBD-II-Code-P0171-and-P0174
You most likely have a vac leak. Hope this helps Fix Ya! Show some love with positive feedback if this brings you to a solution. Thanks Happy Hanna-kwanz-mas
Need tofind out code 51 for 1997 jeep grand cherokee 4x4
Code 51 is ( Right Rear Fuel System Lean ) A lean air/fuel mixture has been indicated by an abnormally rich correction factor. Did you get this code by the flashing check engine light?
Check Engine Light
Your diagnostic about this CODE is:
Generic P-Code DRB Scan Tool Display Brief Description of DTC
P0171 (M) 1/1 Fuel System Lean A lean air/fuel mixture has been indicated by an abnormally rich correction factor.
P0320 (M) No Crank Reference Signal at PCM No reference signal (crankshaft position sensor) detected during engine cranking. P0320 (M) No RPM Signal to PCM (Crankshaft Position Sensor Signal to JTEC) A CKP signal has not been detected at th
For more details, you can visit the obd_dtc_jeep
Good luck, and rated this help.
2answers
Which is it? Carburetor ice or water in gas?
Hmmm.. Your van has No carburator.. Its direct multiport fuel injection.. It sounds like you have excessive moisture in the tank and lines.. Id try a new fuel filter..
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
