Computers & Internet Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I password protected my bios and don't know how to know how to remove it so i was going to remove the cmos battery
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 144 Answers
  • Posted on Apr 15, 2009
Anonymous
Expert
Level 2:
Mentor:
Answers
144
Questions
Helped
42617
Points
352
Removing the battery will not make a difference, it wil remove the system clock but he bios runs on non-volatile memory (memory that runs without power so you will not lose the password. Due to security reasons and without legitamate proof, i cannot tell you how to remove the password as the computer may have been stolen. let me know if you have proof, and i will TRY to help you.
I forgot BIOS Password
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals and search them for Bios Password or Bios Password Reset.
I searched and Toshiba did not have any manuals or drivers for this model. Must be really old.
Anyway try the link below for removing the bios password.
http://www.ehow.com/how_6795884_reset-toshiba-tecra-bios-password.html
You could try removing the cmos battery.
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.
I don't know my security code
if you are referring to a password protected hard drive
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
also
hope this helps you
My laptop HP ProBook 4510s prompt computer open password befor going to BIOS or OS. And i don't know what is the password? So how can i reset the password to boot the computer.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps you
3answers
Hello, My name is Vahe and I have got the following problem, I have forgot my BIOS password and I can't to turn on. Laptop model Toshiba satellite A200-13M. So I have got some solution to delete...
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
1helpful
6answers
Dell Latitude D620 BIOS password help!!! I bought a Dell D620 and I noticed that some BIOS features are password protected. The previous owner said he doesn't know anything about it, so I'm not sure what...
Dell usually sets a default password as password or admin Try those first. If no luck go into the bios setup by continually tapping the exc key while the computer boots. If your licky you may be able to set yourself as administrator and give yourself admin rights. With admin rights you can do anything.
My computer shows a message like this on the start : "this computer system #7WQ6V3J-595B, is protected by a password authentication system, since i bought this laptop in a "used sale fair" i dont know...
the computer has been locked from the bios settings.
What you need to do now is to access the Cmos battery on the laptop, remove the Cmos battery and turn on the laptop without the Cmos battery.
The Cmos battery is where the laptop memorizes the password and stores it. So when the Cmos battery is absent, the computer cannot remember any password
The Cmos battery is like a watch battery, but its bigger than a watch battery. You can find the Cmos battery when you loose the laptop from under. But you must first remove the laptop battery before you loose the laptop. You can open the link below to see what a Cmos battery looks like:
http://images.google.com/images?hl=en&q=Cmos%20battery&aql=&oq=&um=1&ie=UTF-8&sa=N&tab=wi
You can also check the below link for more information about the bios.
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
Take care.
1helpful
3answers
Bios password cant boot password protected
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
4helpful
4answers
How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
I neeed clear bios cmos and cmos run to my hp ze4315us
Restart system holding down f11 key till it beeps. Dont forget to backup your documents.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
