SOURCE: remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
SOURCE: Dyson lsoing suction
There is a guide to pulling apart the Dyson DC05 to replace a burnt out motor at www.tasweb.org
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
SOURCE: We have an Electrolux 6500 SR Model C102G. We
yes it wears out it is a common problem i eliminated several of them for people its a job that takes alot of patience i opt to just eliminate the part its sort of useless and causes your machine to act contrary if you want to replace the part here is the place
Electrolux Aerus
4526 Maccorkle Avenue
South Charleston, WV 25309-1409
(304) 768-2158.. if you cant fix it contact me and i will repair it for $35.00 plus parts or no parts either way it can be fixed the above contact is the dealer i use for parts
SOURCE: Disassemble electrolux olympia one vacuum.
Before taking the machine apart, always check for clogs in the hose and power nozzle, full bag, and/or plugged hole under the bag. Suction/vacuum loss can also be caused by leaky or cracked hose, including the section in the power nozzle.<br /> The best way to check for clogs is simply drop a large marble in one end and let it roll through. To check for leaks in hose, hook to exhaust port, pour a small amount of liquid dish soap in other end of hose, lift high and turn on vacuum. Bubbles will appear at badly worn spots and cracks in hose.<br /> There is no need to pull out the motor, as their is no filter surrounding it, motor does not need lubrication, and the above check should result in locating the problem.<br /> Repair manuals are only available to Electrolux franchise owners as highly restricted software.
