The display is barely visable, and looks like a photographic negative on my Toshiba Satellite 4010 CDS/CDT laptop
You most likely have a defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
mightymoe, geekman,
Thanks for the suggestions.
My screen is dim, even at boot up.
Running Windows Pro 2000
Is it dim when booting up even before it gets to the Windows screen? Assuming you are running windows. If it is dim even before it gets to the windows screen then the lcd needs replaced. If not and only gets dim when in Windows mode then it is more than likely a driver issue.
Let me know.
