SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: magicolor 2530 DL Laser Printer: reset image drum 2530...
I had this same problem however I was using the Magecolor 7450. I was trying to print a C5 postcard and the right hand side of the document was getting cutoff (aprox 2 in). Changing my Paper-Type settings on the printer from "Postcard" to "Any" magically fixed the problem.
I hate this printer.....
CAUSE: The transfer belt is not rotating correctly inside of the Image Unit.
SOLUTION: Check the PRCB connector for proper connection and correct as necessary. Also, check Belt Positioning Sensor (PS6). Replace Image Unit (p/n A0VU011). The PRCB may also need to be replaced. (p/n A034 H001 06 for magicolor 1650EN or p/n A034 H009 07 for magicolor 1680MF/1690MF)
SPECIAL NOTE: Solution contribution by SSD Printer Support
ID No.
TABP1000085EN
FROM KMBS SSD
