Troubleshooting & Support
Hot Topics:
- media jam fuser
- reset
- magicolor 2430
- parts
- fuser
- 2430dl
- windows 7...
- replace...
- error
- toner life end...
- err line 2474
- paper jam
- fatal error 17h
- video underrun
- 2430
- service manual
- clean
- replace drum...
- firmware
- paper jam fuser
- vertical streak
- error 2474
- Drum
- reset counter
- clean lens
- lines
- driver
- toner not...
- toner missing
- toner life end
- View All »
Problems & Solutions
Re- 2430 DL Hi I had
It will be pace of paper inside very small, see, find it and will be print,
I have a Magicolor 2430
Hello This issue is caused by the drum starting to fail. the Drum is what transfers the Toner to the paper and when it fails will cause...
Please describe how to clean dirty edges on the
Inside these machines is a rather large, black sheet that is known as the transfer belt. This belt acts to transfer the toner from the drum...
the konica minolta magic color 2430dl driver i
download it from this link, www.mykonicaminolta.com
My printer is printing a duplicate image along
The most common issues for duplicate image is either the drum or fuser. If you are able to measure the distance between the first line and...
CYAN TONER NOT INSTALLED
check toner lever onside of cartridge youtube has way to repair
Paper jam in the fuser. do you have a rebuild kit?
I couldn't find anything for rebuilding a Konica fuser, but here's an eBay listing for new ones under $100 plus shipping. This is...
konica minolta 2430 DL paper jam
Make sure your printer is on a flat level surface. Having a cord or anything else under one edge or the other, over time, will cause...
I am getting cyan toner cartridge not installed on
I found a solution on here that said clean the contacts on the toner cartridge on both ends with an eraser and I did and that stopped it. On...
minolta 2430dl X toner not installed
On December 16, 2010 I called 800 972 6705 to order a "crum unit" 4139R73511 (note updated part number) to replace the crum unit. ...
I've installed drivers & can't seem to
You must install the software before you connect your magicolor 2430 DL Laser Printer . Load the installation software and connect the...
When I print in colour there is a white streak
If you remove the drum, inside where the drum is a small glass panel if you clean this the white line will go away.
how to rotate toner cartridges to replace K
Well on my 2430DL the release for the toner carousel is definitely not where komguy says it is. Open the top cover and on top of the printer...
Broke off the door on top where paper is
try it from KONICA MINOLTA manafacuer then might do it
'DRUM CARTRIDGE END OF LIFE' MESSAGE
The back right of the drum has a small 20mm F80mA fuse that you need to replace to reset the drum counter. (fuse blows to reset the drum...
See all Konica Minolta magicolor 2430 DL Laser Printer Solutions
Unsolved Problems
Minolta Magicolor 2430 DL does not work in windows...
does this printer work in windows 7 ?
Where can I get a new paper tray for my magicolor...
The little round ends broke off, I need a new one
I replaced my drum on my magicolor 2430dl but when...
I replaced my drum on my magicolor 2430dl but when I print color copys the paper comes out blank then the media jam...
wants duplexer
My printer keeps indicating stopping indicating that the duplexer is not installed. This is correct, but I am not...
Where can you purchase Konika Minolta ~Magicolor...
I am looking to purchase Image Transfer Belt Unit
konica minolta driver for vista 32bit
Download can't seem to install driver on Vista 32
problem with color
ok prints black great, when printing color no image but the image is on the transfer belt not on the paper but as i...
See all Konica Minolta magicolor 2430 DL Laser Printer Problems
Upload a manual for Konica Minolta magicolor 2430 DL Laser Printer
Specifications
TopKey Features
Full Product Name:Konica Minolta magicolor 2430 DL Laser Printer
Platform:PC, Mac
Type:Workgroup
Technology (Detailed):Electrophotographic Laser
Black Print Speed:20 ppm
Output Type:Color Printer
Max Resolution (BW):2400 x 600 dpi
Color Print Speed:5 ppm
Technical Features
Form Factor:Stationary
Connectivity Technology:USB 2.0
Connectivity Technology:RJ-45 Network Adapter
Duplex Printout:Manual
Monthly Duty Volume:35,000 Pages
First Page Out Time:12 Second
Direct Printing Capability:Print Photos Without a PC
Media
Media Type:Transparencies
Media Type:Plain Paper
Media Type:Envelopes
Media Type:Labels
Media Type:Glossy Paper
Media Type:Postcard
Max Media Size:Legal (216 x 356 mm, 8.5 x 14")
Total Media Capacity:200 Sheets
Networking
Networking Type:10/100BaseTx
Data Link Protocols:Ethernet
Data Link Protocols:Fast Ethernet
Memory
Installed RAM:32 MB
Max Memory:544 MB
Processor
Processor:ARM 9 RISC
Processor Speed:200 MHz
System Requirements
Operating System:Apple MacOS X
Operating System:Microsoft Windows 98 SE
Operating System:Microsoft Windows ME
Operating System:Microsoft Windows XP Home Edition
Operating System:Microsoft Windows 2000
Operating System:Microsoft Windows NT
Operating System:Microsoft Windows Server 2003
Operating System:Red Hat Linux 8.x
Operating System:Suse Linux 8..x
Warranty
Warranty:1 Year
Dimensions
Depth:19.8 in.
Height:13.4 in.
Width:16.9 in.
Weight:39.6 lb.
What's your problem?
Fix-O-Meter
66,164
66,164 people have viewed this product
- 477 people asked about this product.
- 201 people found solutions for this product.
- 9 people have added this product.
How to resolve...
Getting help...
Konica Minolta...
