My son gave me digital photo frame with grandchildrens photos, i would like to know how to put them on my laptop so i can print my favoure ones Thanks
Hello, moving the pictures from the photo frame to your laptop shouldn't be too difficult. First, we'll need to know what kind of laptop you have (make/model) and what kind of photo-frame you have. These two pieces of information will help us determine how your photo frame stores the pictures, and the best way to get them to your laptop.
Hi, re details for frame and laptop. The laptop is an ACER extensa 5220, and the frame is a coby DP 700. Thanks
Dennis,
good news - your photo frame uses a removable SD card that pops out of the frame which contains the pictures. Your laptop has a matching card-reader in the front of it. If you remove the card from the frame and insert it into your laptop, your computer should automatically pop up and give you some options to view and print your pictures. Good luck!
brilliant,spot on, many thanks,
SOURCE: Matsui 7" digital photo frame
I got one for xmas and pics download easily every time. I connect my camera to the laptop then load the shots I want onto the SD card on the camera, disconnect and remove the SD card from the camera then insert in the frame. I have had no problems with photo size or downloading time. I do have a problem when I remove images from the SD card however. The frame still displays images that I deleted and are not showing when I connect to the laptop! Can anyone help?
SOURCE: IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
SOURCE: 7" Trutech digital photo frame Calendar
Use the Navigation Buttons to select "Calendar"; press Enter to confirm. To set the date, press the Stop Button and then use < and > Buttons to adjust the year and the arrow down and ^ buttons to adjust the month; press the Stop Button again to confirm. Then, use the Navigation Buttons to select the current date on the calendar display and press Enter to confirm. To exit press the Menu Button.
SOURCE: transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer
Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See for applicable file formats.
1. Connect the USB cable from the frame to your computer (Connecting to your computer).
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
SOURCE: I can't load photos onto my digital photo frame
The A701 is a bit cranky. I've found that it prefers USB flash sticks of upto 2GB. It likes the flash stick formatting before use. And it prefers jpg files added to the root directory of the flash stick - so no images in folders. Finally but probably least important, it's not much point uploading 2MB jpgs as the screen is pretty much 72DPI smaller size JPGS lead to a faster loading. ( try around 900x 600 dpi )
