its asking for my ip address and sub mask no. it just got back from the factory after being repaired for the three rings. It was working fine on live before I sent it.its asking for my ip address and sub mask no. it just got back from the factory after being repaired for the three rings. It was working fine on live before I sent it.
It may have trouble recieving the ip addrees from the router, but not sure what switch you are using if you have a router you should connect directly unless its a wireless switch.
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
To get a wireless internet connection for Xbox live, you will need a high-speed Internet connection such as cable or DSL and a router, gateway, or wireless access point (WAP) that is compatible with Xbox live. If your XBOX360 console is first generation, you will also need a Xbox 360 wireless networking adapter. If you are using a wired connection, you will need a network cable. Plug the network cable into your router and the other end into your Xbox 360. On your Xbox 360 console, navigate to "MY XBOX" and then select "system settings" Next select "Network settings" and then select "Test Xbox Live connection" Select YES when the prompt appears asking you to update your software. After you become connected, there are two choices: Free membership of Gold membership. Once you are connected, navigate back to "My XBOX" and select your avatar and then select "Join Xbox Live" If you need any more help feel free to contact me. Thank you for using Fixya
Before you
connect any cables, turn off your router, modem, PC, and Xbox 360
console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem
and the other end to the Ethernet input port on the back of your
router.
With another Ethernet cable, connect one end to one
of the router's Ethernet output ports. Connect the other end to your
PC's Ethernet port.
With the third Ethernet cable, connect
one end to another of the router's Ethernet output ports. Connect the
other end to the Ethernet port on the back of the Xbox 360 console.
Turn on your modem, then your router, then your PC.
Make sure your PC can access the Internet. If not, you may need to
configure the router for Internet access. For help configuring the
router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console and sign in with your profile.
If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
just to elaborate on zombies post..... Zombie is correct in what she says...but in 'Laymans' terms......... you dont need to hook up your xbox to ur computer to get 'On Live' . The easiest way is a direct 'Ethernet' lead (plugged into the back of ur 360....(dont worry....u cant put it in the wrong slot....an ethernet lead will only fit an ethernet slot)) & the other end into an empty Ethernet slot on your broadband suppliers router (the little box they sent you which is plugged into ur fone line)....there are usually '4' ethernet slots on most routers ! once the ethernet lead is plugged in just follow on screen instructions (xbox) for 'signing' up to 'Xbox Live' :-)
hope this is a little easier to understand ??
p.s. Dont get ripped off buying an ethernet lead if u havnt got one long enuf ! dont let the shops tell you ur better off with 'Gold' plated ones !! its rubbish !! u dont need gold plated ! the usual 'bay' shop (u know who i mean??) have numerous suppliers....u dont want to be paying more than £5 for at least a 5 metre one !
p.p.s dont bother with the wireless adapters !! there pants !
you either ethernet port is probably broken this happend to me recently and i could have sent it in for 99 buck or get a wireless adater so i got it from my friend and the wireless adapter works, because it bypasses the ethernet port and wirelessly connects to your network and xbox so try that out but dont buy it borrow it and make sure it works
You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
So it is modem to router wan port
Xbox 360 to router lan port
Computer to router lan port
You can purchase one cheaply at best buy
look at this link
You can try fixing this using Xbox360 repair guide that covers almost all xbox 360 problems, you can get a copy from here http://xbox360repairguide.com
Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
Turn on your Xbox 360 console with no disc in the disc tray.
If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
bioshock and assassins creed keeps jumping on brand new xbox 360 elite
