3 digits, nothing else which can be pushed or pulled, the two key locks on either side are OPEN Please please help, travelling in 1 week Thank you
Follow this steps and fix it. God bless you
Otherwise you must go to website from you manufacturer supplier and get support via ONLINE chat.
Enter either the preset factory code or the the current user code.
Press the "1-2" button. You must do this within five seconds
of entering the current code. The door will lock and then unlock to
alert you that the system is ready for programming.
Enter the new five-digit code. You can't wait more than five seconds between entries, or the process will be aborted.
Press the "1-2" key to store the code for driver one. The
door will lock and unlock to let you know you entered the code
successfully. The system can have a total of three drivers. To set the
code for driver two, you would press the "3-4" key, and for driver three
you would press the "5-6" key.
SOURCE: 2001 Jeep Cherokee sport. Power door lock won't
Lock and unlock both run off the same power supply...I'd be looking for a bad switch or a broken wire in the door harness where the wires go through the rubber boot between the door and pillar.
SOURCE: 2005 buick lacrosse
lock rod has probably come off from door lock, try to get inside panel off or have someone with slim jim try and reach the rod to unlock the door
SOURCE: central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
SOURCE: Drivers Door Lock Problem
You will probably need to replace the power door lock actuator.
Here's a link to one similar to yours.
http://autorepair.about.com/library/a/1g/bl467g.htm
You can probably get a used one from a salvage yard.
Try this site to find one near you:
http://car-part.com
If you need more help post a comment.
Tim
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
