Question about Luggage & Travel
Resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Posted on Mar 26, 2018
SOURCE: change luggage key combination
Email from Samsonite in response to my plea for help:
Dear Sir/Madam:
The following are the lock picking instructions you requested from Samsonite Consumer Relations.
1. Position the luggage so that the numbers on the wheel are
right-side-up as they face you and set all three wheels to “0′.
2. Starting with the wheel on the left, to the right of the wheel,
look into the narrow space between the right side of the wheel and
the body of the lock. Look down into the shaft. (If you have a
safety pin, straight pin, or thin nail file, place that in the
narrow space.)
3. While looking down into the shaft, rotate the wheel slowly. You
are looking for an indentation (a square notch). When you find
the indentation, stop and write the number down. (If you are using
a tool, the tool will fall into the indentation.)
4. Follow the process for the remaining two wheels.
5. Try to open the piece of luggage.
6. If the luggage still will not open, please try the following:
a) If the number on the wheel is over 5, subtract 5 from the
number showing. For example, if the number showing is 8 turn
the wheel to 3 because 8-5=3.
b) If the number is under 5, add 5 to the number showing. For
example if the number showing is 2 turn the wheel to 7
because 2+5=7. The numbers showing on the wheels will be
your combination.
If you still have a problem with the combination lock, contact the nearest authorized repair center to your zip code for repair assistance. Our warranty and repair information can be viewed at http://www.samsonite.com under the heading “Customer Service Repair Centers” for your reference.
We appreciate your loyalty and will continue to design products that are reliable business or travel companions.
Posted on May 05, 2009
SOURCE: I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Posted on Oct 11, 2009
SOURCE: Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Posted on Dec 04, 2009
SOURCE: presto combination lock on a suitcase will not open
my mother in law has a norton suit case and needs keys the number on the lock is 332 norton do not excist anymore where can i get replacment keys from?
Posted on Mar 01, 2010
SOURCE: how to unlock a tsa lock that I forgot combination
I have a new carlton misha cabin case and it has arrived with on of the zip arms in the lock and I cant get it to move and have not been given the code, could some one help please
Posted on Nov 13, 2010
Oct 03, 2014 | Locks & Locksmithing
Aug 23, 2014 | Delsey Helium Shadow - 25 Trolley Luggage...
Aug 31, 2013 | Luggage & Travel
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Nov 08, 2009 | Samsonite Tripod
1,815 people viewed this question
Hi Beverly Ramos, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make and model of suitcase?
Could you contact the retail or internet site you purchased it from for assistance?
