Tried to start windows in normal mode and it staying in safe mode. Tried to system restore and that didn't work. I do not know how to reboot my system. Also everything is 50% larger in safemode and none of my programs like microsoft word 2003 and 2007, javascript, adobe, anything at this point doesn't work.
Boot your computer in safe mode, then check the resolution.
Also try to boot your computer in Last known Good configuration, if that doesn't work either then try the following steps as there might be some system file issue:
Log in to the system as you do in usual
insert the OS installation disk(xp)
Press Ctrl+Alt+Del to view the task manager.
Press new Task .
Now write this in the field( sfc ' '/scannow)
Note :-
Instead of ( ' ' ) press space there is no another spaces
ok
if you do it correctly you will see a window that copy the files of the
system from the CD/DVD to your PC to fix the corrupted files.
Tell me if that works.
Askari:)
