To joecoolvette reguarding 2005 compaq presario SR1000 and Dell LCD TFT monitor. The dell monitor was part of my mothers comp and I wasnt given a CD with it. Im sure she dont have it now. As far as the...
jason,
When a device is installed, Windows 'Breaks it's neck', to find a compatible driver, (Or drivers)
If THE driver is not present, then Windows will match up one of it's thousands, of generic drivers it has on hand.
Then if THE driver is installed, there is a driver conflict.
{Crude illustration}
Windows: 'Which drivers do I use? These or THESE?'
Let's try this;
{Based on Windows XP operating system}
1) Left-click on,
Start>
Control Panel>
Add/Remove Programs
When Add/Programs populates REMOVE the graphics cards software.
ALL of it. Anything you see associated with that graphics card.
Close all windows, go back to your desktop screen.
(If you are asked in Add/Remove Programs, if you wish to restart your computer - NO)
Shut your computer down normally.
(Start>Turn Off Computer>Shut Down)
Unplug your computer from power. Open the computer case, TOUCH the metal frame to relieve your body of Static electricity.
(Static will fry out your computer hardware components)
Remove the graphics card.
Press the Power On button in, and hold it in for a count of Five seconds. (And I mean Five. Count - 1001..1002..1003..1004..1005)
Let go of the Power On button.
Do this same procedure Two more times. (Imperative!)
What you are doing is clearing CMOS Error Codes, and resetting your BIOS Setup back to the factory default settings.
Now plug your monitor into the VGA port on the motherboard.
Plug your computer back into power.
WAIT 1 minute.
Turn your computer on.
When Windows has loaded all the way, put the CD disk for your graphics card in your optical drive tray. Load the software.
When you are finished, close all windows, go back to your desktop screen.
Unplug your computer from power. TOUCH the metal frame. Install your graphics card.
Plug your monitor into the graphics card.
Close your computer case.
Plug your computer into power. WAIT 1 minute.
If the resolution isn't correct:
Right-click anywhere on an empty spot of your desktop screen.
In the drop down menu, Left-click on Properties.
Now left-click on the Settings tab, all the way to the right.
Look down at where it states - Screen resolution, in blue.
(Halfway down the Display Properties window)
Is the pixel resolution what it should be?
If not, Left-click on the slider.
Hold your left mouse button down, and slide the slider, to where the resolution settings are correct for your Dell LCD monitor.
(To the left is Less. To the right is More)
Now go down to the right, and click on Apply.
Then go over to the left, and click on OK.
Don't know what the native resolution, for that Dell LCD Thin Film Transistor monitor should be?
Look it up on the internet using the Model Number, or give me the Model Number, and I'll look it up for you.
Sounds like an overheating or battery problem to me. Need more information to determine the cause.
