20 Most Recent
Samsung SyncMaster 912N 19" Flat Panel LCD Monitor Questions & Answers
The magicbright screen appears in
The magic bright screen should show up once the magic bright button is
pressed on the control panel. The magic bright button (is a sensor) is
very sensitive. Make sure that there are no objects hitting any buttons
The control panel uses a sensor behind the smooth
plastic bezel to register when your finger touches a 'button'. Clean the buttons or the sensors using a soft brush.
Try to power cycle the SyncMaster. Disconnect it from the outlet and
from the computer. Leave it disconnected for about 30 minutes then turn
it back on.
If you get the same problem, then there's a problem with the sensor and
needs to be serviced. If the SyncMaster is still under the warranty
period, contact the manufacturer for repair.
Hope this helps and have a great day!
3/27/2016 5:44:41 PM •
Samsung...
Answered
on Mar 27, 2016
My monitor keeps going blank
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK MEhere's the serial : JCCQ-MAKC-KACK-6TSE-BN35
4/21/2012 6:39:07 AM •
Samsung...
Answered
on Apr 21, 2012
Syncmaster 912n red tint problem
Hello,A red or pink tint on LCD monitors indicate that the back light florescent bulbs are about to go out. Just like on regular florescent these bulbs are just much smaller but burn out just the same. Check the date on the back of your monitor, if it is less than 3 years old then its still under warranty but if its not then its time for a new monitor. The bulbs can be replaced but it really is not worth the trouble.
2/9/2012 8:55:07 PM •
Samsung...
Answered
on Feb 09, 2012
Screen black with error message
follow theses instructions to resolve your problem :
- Restart your machine
- Press F8 rigght before Windows bootup
- In the menu select "VGA mode".
- Once your system boots, click with mouse right button on the desktop.
- Select Screen Resolution/Properties.
- Navigate over the windows, until you found the resolution categorie.
- Change your resolution to 1280 x 1024 or lowest one, 1280 x 1024 is Max.
- Press OK, and then confirme your choice.
- Enjoy.
12/26/2010 10:31:48 AM •
Samsung...
Answered
on Dec 26, 2010
Frontbuttons
These buttons are used to control the various setting of the screen, such as Brightness, Contrast, Height, Width, Pincushion, and various others.Usually one button, usually the MENU will bring up the master menu, the other buttons are Left & Right. are used to go up or down with the settings, or + & -, Repeated presses of the button(s) will advance it on to the next setting.
11/30/2010 9:31:32 PM •
Samsung...
Answered
on Nov 30, 2010
The monito remain in the
Hi thanks for asking, when the monitor is in standby mode it mean the computer is on but in a hibernating or sleeping stage. To get the computer out of this mode you should restart the computer,if that does not solve the problem you should connect the monitor to another computer to see if it will work the usual way you can connect it to a laptop or desktop computer the monitor will work on both.After you connect the monitor to another computer if the monitor work fine on the other computer, you should connect another monitor to your computer if the problem still exist this mean that the video card in your computer is bad and need to replace. If the monitor does not work on the other computer this would mean that the monitor has a problem.
If this solution help you can give it your vote and rating
thank you
6/17/2010 9:07:42 PM •
Samsung...
Answered
on Jun 17, 2010
