SOURCE: show paper jam without actual
1.check the back cover is open and the green levers are down.
2.open the front cover remove the cartridge ,you can see a green lever ,just lift it up and see any paper pieces are there.
SOURCE: I have PH Laserjet P2055 printer 49 err 4810E9E
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
SOURCE: L7157 HP Laser Jet P2055
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
