L7157 avery labels start off in centre on labels but by the end of the page they are off the sticker i am using a HP laser Jep P2055 printer
Unfortunately, this is a common problem. I suspect you're using MS Word to make the labels. Word takes the font and the dimensions of the labels and is supposed to transfer the correct sizes of everything to your printer. All to often it doesn't do this correctly.
One thing to try is a couple different fonts to see what happens. (use plain paper to experiment, it's cheaper.)
The other way is to set up a regular page in MS Word with 3 columns and fill the page with copies of your information. The trick is to adjust the font size on the empty lines between your information.
address line 1
line 2
line 3
[font size adjusted empty line]
address line 1
line 2
line 3
SOURCE: number of pages tracking on daily basis in hp1018 laser printer
try Printer Test page
The Printer Test page contains information about printer driver and port settings. The page also contains information about the printer name and model, computer name, and so on.
You can print the Printer Test page from the printer driver.
is it on the network? login to the printer using http://<ipaddress of printer>
other option is to contact hp support online.
SOURCE: I have missing my HP laser jet 1020 printers CD
Select your operating system and download the driver for it.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=439320&lc=en&cc=us&dlc=en&lang=en&cc=us
SOURCE: how do I clean the rollers on my laser jet
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
SOURCE: hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
SOURCE: HP color laser jet printer is displaying error
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
