The agitator secures to the bottom of the tub by snapping over the drive bell in the bottom of the washtub. Some agitators have a bolt under the agitator cap, although many will not have a bolt. www.rubberfloorings.co.uk
SOURCE: Kenmore elite HE3t
F2 is a drain erro. Take the 3 screws off the botom panel in the middle, bottom you will see a large white plastic looking pump. this unscrews counter clock wise. have something ready to catch the rushing water. The trap is probably full of the rubber backing or strands of the rug. After you unscrew it, there is a trap there that can be cleaned. You may have to repeat this a couple of thimes to get all of it out.
SOURCE: Washer stopped at begin of wash cycle
The problem seems to lie in the rubber backed mat. If the rubber has begun to peel of the mat it often-times get stuck in the drain pump. The best thing to do at this point is to disconnect the electrical cord, open up the machine, drain out the water as best as possible disconnect the power cord to the drain and the hoses. Clean out the drain pump. reassemble. You should be good to go., Unless the drain pump is burned out (left running plugged up too long) if thats the case, replacement of the pump may be neccessary.... Hope this helps...Good luck!.... Bill
SOURCE: I can't get the front panel off my HE3 #44836 to
Read the owners manual. Many washers have 'self cleaning' filters that will get clogged with big stuff. The 'moldy odor' is caused by MOLD. Run a 'extra large' empty load of HOT water with normal detergent + 1 PINT of ordinary bleach. Add another shot (pint) of bleach to the rinse cycle. Sometimes a small article (sock?) will escape the clothes basket and get trapped in the tub--it can't get drained out and can't get back into the clothes basket. The bleach will kill the mold, but if it returns you will have to take the top off and fish the lost article out using a bent clothes hanger as a hook.
SOURCE: Rubber mat flakes in washer
it will cause a clogged pump
take off the back wall
you will see the pump
unplug it
ctake off the two hoese( make sure botha re clear)
ensure pump is clean
reinstall and you should be ok
SOURCE: How can I spin dry bath mats??
you gotta add a few more items like some towels, try it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
