SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
SOURCE: GE JBP30 oven bottom element not working after being replaced
I would be looking at the bake relay on teh coven control board. Using a voltage meter test the output voltage when energizing the bake feature. Be sure to remove the bake element wire coming from the bake element to the control. Test this terminal without the bake element wire attached. From the terminal with one meter probe to the neutral on the terminal block (where your cord attaches to), you should read 110 volts when energized and 0 voltge when shut off. What are you reading? If I can help further, I am here.....
Waiting to hear from you,
Eric Campion
SOURCE: The bottom heating element in the oven has stopped working
It isvery easy to replace just unscrew the bottom heating element (unplug stove first ) take it to home depo or appliance store and get a replacement and screw it back on......then plug stove in ...
SOURCE: need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
