20 Most Recent GE JBS55 Electric Kitchen Range Questions & Answers
hello,
I can not better explain it as described in the link I send you below.
I hope this helps, Dik
Oven Thermostats Help Advice Fitting
GE JBS55... | Answered on Feb 18, 2018
Power must be reaching the stove for the lights to work so it would seem something has gone wrong inside the stove. Only exposing the internal connections and testing the circuits will trace the fault.
GE JBS55... | Answered on Apr 30, 2017
Check to make sure you have 240v at your receptacle. Lights, clock, timer, will still work with 120v, while the elements need 240v. Start by checking your breakers to make sure that one of the two breakers feeding your oven hasn't tripped.
GE JBS55... | Answered on Jun 07, 2010
Most of the time the replacement is really not that hard...here is a tip that I wrote about that...
Range/Stove/ Oven Door Glass Replacement
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
The very bottom link on this tip will help you with getting the part online...
heatman101
GE JBS55... | Answered on May 11, 2010
bad clock or ecu
GE JBS55... | Answered on Nov 15, 2009
This is a very serious hazard if the circuit breaker trips just when the oven begins to heat up. The circuit breaker could have become weakened and needs to be replaced ASAP. Have an electrician check and replace.
The oven could have been placed on too small a circuit breaker OR the total number of appliances on that line has pushed the circuit breaker over it's limit. The Oven draws a huge current and may be the straw that broke the camels back.
Check to see what other appliances are shut down when the breaker trips. See if you can place some or all of these on another line.
Leaving the Oven on the one circuit breaker. This will hopefully prevent the overload situation that is occurring now.
If it still trips... get an electrician in there fast!
Hope this helps!
GE JBS55... | Answered on Oct 04, 2009
It could be a faulty motor or a faulty motor start capacitor
GE Kitchen... | Answered on Jul 11, 2019
do a search or buy universal set that are compatible
GE Kitchen... | Answered on May 29, 2019
GE JBS55 Electric Kitchen Range Logo
Popular Tags
22 questions posted
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
GE Kitchen Ranges
  • GE Kitchen Ranges
Most Popular Question
ge jbs55w0j3ww electric oven will not
  • Kitchen Ranges
