When starting up your PC, press del tab to enter BIOS. Inside change the USB settings to FULL SPEED if it was enabled at HIGH SPEED else the opposite. Also check the USB slot and make it free from dust or u could clean it with Ethyl Alcohol. Now try......sodeep
Either the USB port is not working or the Windows software is not recognizing the ports. To resolve the Windows issue, go to Start, at the Run prompt type SFC /SCANNOW. Be prepared to insert your operating system disk in the CD drive. If this works try the USB port again. If this does not work and you have confirmed that all your USB ports work the same way and that your USB device is Ok then the system needs to go to a repair person.
If possible, try opening the cabinet and check if the wire leading to the front usb port is properly connected. best would be to take your pc to the nearet customer service.
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Flash Drive to be detected automatically.
I have a solutions that might work, please for the love of god, next time give it as much detail as possible. Navigate to Start>run type:MSCONFIG. Enable everything unless you are absolutely sure you don't need it. Right click on My Computer, click on properties. Go to the hardware tab at the top, click on device manager to see if there is a conflict. Try a different port. Try the hub on a different computer. If your hub has a power input, now would be the best time to plug it in. Plug directly into computer. Make sure the device is plugged in securely, same goes for the devices plugged into it. If that port is for power only and you plugged it in thinking it would work for data, please don't ask. Any error messages? If your computer can boot off a flash drive, Go to bios, test the port and the hub.
clean your usb port if it does not work open my comp then watch in that window and keep inserting and uninserting until u see my comp reconize it if you have to do the ladder it is time for a new flash drive they do not last forever
