Microsoft Office Standard for PC Logo
Posted on Aug 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In Word 1. The Column Shortcut for Keyboard 2. .org Shortcut 3. Powerpoint Shortcut for open in RUN 4. Plz Send The Shortcuts
Anonymous
Level 3:
  • Master 944 Answers
  • Posted on Aug 25, 2007
Anonymous
Master
Level 3:
Answers
944
Questions
Helped
786930
Points
2417
What aspect of the Word "Column" Feature do you wish to use from the keyboard, or do you just wish to open the column drop-down menu with a keystroke? Open "Tools - Customise - Keyboard" then you can select "all commands" in the "categories" window. Scroll down until you find "columns" and assign a key shortcut. If you wish to link to a .org webpage, then use "Ctrl K" to insert a hyperlink. If you wish to configure a hotkey to automatically type ".org" when pressed then this is possible. You have to first record a macro. Open "Tools - Macro - Record Macro", give it a name you will remember and select Keyboard. choose a key shortcut that is free. I recommend "Shift F12" but find what you prefer. Then type ".org" and click the small blue square (stop macro). The key you chose should now type exactly what you typed every time you press it. If you want to open powerpoint with a hotkey, this can be done. Select "Tools - Customise - Keyboard" then you can select "all commands" in the "categories" window. Scroll down until you find "MicrosoftPowerpoint" and assign a key shortcut. Hope this helps, please ask again if you need more help. :)
  • Anonymous Aug 27, 2007
    What further help do you require?
Anonymous
Level 2:
  • Expert 53 Answers
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
45244
Points
108
Hi check here http://www.statisticalexperts.com/forum/redirect.php?goto=newpost&tid=5 Good Luck.
  • Anonymous Aug 25, 2007
    start =>run => C:\Program Files\Microsoft Office\Office12\powerpoint.exe
3helpful
2answers
All folders on usb flash memory card changed to be shortcuts , I can't display their contents directly , there is folder called recycler contain an index for the data inside my folders ... i want...
Hello there, sadly you have been attacked by a virus named - RECYCLER. This is a very common virus, I also had an encounter with it recently. What zou are going to do in order to delete is:
1.Look for all folders with shortcut arrow.
2.Right click then properties.
3. in the field TARGET delete everything before path to your usb (before eg. F:/Kobac usb).
4.Save settings. Open folder and copy it to harddrive
5. Do this for all folders.
6. When zou finish coping your data, format your USB.
7. To Format fo to My Computer, right click on USB and format.
8. Copy files from harddrive to your USB back
9. Enjoy!
Good luck, Kobac
2answers
Shortcuts on desktop etc all recieve message asking what program to use to run the shortcut program?
Please can you provide details of what the shortcuts are pointing too that arnt working
2answers
4 gb usb creating shortcuts folders
I think you are referring,that there are folders and shortcuts which are not created by you and its generating automatically?
if this so, Its an action of a virus. - Run full system scan using a up-to-date virus scanner.
1helpful
Re HP wireless Elite keyboard (RK713A): I am using it with a Sony notebook (Windows 7) - can the F9-F11 keys somehow remapped to something useful eg. open Outlook etc. ? (Registry?) Thanks!
Here's the Microsoft way - note that all Win7 keyboard shortcuts begin with CTRL-ALT-(your shortcut key here).
Note also that a desktop shortcut must already exist to which to be invoked by the keyboard shortcut.....
http://windows.microsoft.com/en-us/windows-vista/Create-keyboard-shortcuts-to-open-programs
The way the Internet community does it:
www.autohotkey.com - freeware - allows you to "package" a number of
keystrokes into a "keyboard macro" and invoke that macro thru
the use of a "hotkey." Keyboard macros can be as short as one
function key, but some Win7 function keys cannot be ove-written, such as F5
164helpful
8answers
Removal of shortcut virus in pen drive
Is this the Problem???
Don't format your Flash Drive.
Your data is still there.
Use Shortcut Virus Remover.
  • 100% free
  • Setup file to download 1.1 Mb
  • Installed file 2 Kb
It will recover your all data.
DOWNLOAD !!!
.pps won't open
1. Download the following utility:
http://windowsxp.mvps.org/utils/PPSFix_2_1.zip
2. Unzip the file,
3. Run the utility,
4. Select the file types that you want to fix, and click Fix.
2answers
My desktop shortcuts open with search results page only
1.
Right-click Start, and then click Explore.
2.
Locate the folder, file, or program in the Folders directory, and then click the item to open it.
3.
Click the icon representing the item.
4.
Click File on the toolbar, and then Create Shortcut on the drop-down menu that appears.
5.
Right-click on the shortcut icon that is created.
6.
Choose Send To from the drop-down menu, and then click Desktop (create shortcut) on the submenu that appears.
5helpful
2answers
Adobe Photoshop CS3 Extended Automation Action set won't play
hey, there are three ways in which u can just play actions:
1)just select an action by left clicking it(actions will be located in the actions pallette.) and hit the play button on the actions pallette.
2)just ctrl+click the action in the actions pallette.
3)u can also assign a keyboard shortcut to it.Go to edit menu>keyboard shortcuts>(shortcuts for) drop down menu>choose pallette options. on the top of pallette menu are actions. click it and assign a keyboard shortcut for it.
4)to stop it, just select the action and click on the stop button on the actions pallette.
I think u have not selected a particular action to play.Please do it and see.THANK YOU!!!!!
Photoshop 7.
4)to stop it, just select the action and click on the stop button on the actions pallette.THANK YOU!!!!!
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
