When i turn on the tv there is a pink colour on the bottom and on the sides of the tv screen. how can i fix this?
SOURCE: Sony Digital TV screen colour problems
My sony projection tv seems to be out of focus on all four side.
SOURCE: Colour Problem with ONN crt TV
TV's will show funny colors because of magnetic fields affecting the face of the picture tube. A "degaussing" circuit (a coil of wire around the tube and some kind of control circuit) is supposed to try to neutralize this when you turn the set on. Sounds like it's not working correctly in your TV, or may not be strong enough to counter the field.
A real cheap set may have no degaussing at all, or may have a manual degauss button on the back. Does the owner's manual tell you anything? The connector from the coil to the circuit board may be loose. Try reseating it. (Be careful if you take the back off your TV. Make sure it's unplugged, and be aware some parts - especially the picture tube - can store a charge for a while after the set's off and can give you a nasty jolt.) It's also possible the tube is defective, but unlikely unless the set was dropped or exposed to a large magnetic field (like kids playing with a magnet near the face, or turning off a vacuum cleaner right in front of the set).
Hand-held external degaussing coils are available (check eBay). But without seeing exactly how bad the color is under what conditions it's tough to say what's best to try.
SOURCE: philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
SOURCE: my goodmans CRT TV has developed pink and green
try to replace 3 pcs of ic/transistor at behind the crt socket (RGB ic)
