My Frigidaire GLMV169D stopped working suddenly. I can't locate the fuse in the unit to check
This problem is almost certainly caused by the thermistor failing. The thermistor is located at the
air outlet of the unit. This is a thermal resistor that cuts off the electricity to the unit if it overheats. Sometimes it can fail from age.
Go to;
http://www.appliancepartspros.com/
and enter your unit number. You can even get diagrams in the left-hand corner screen.
Replace with same value thermistor.
Also see if a mini manual in hidden behind the control panel.
