Hello sammyparker1 - Thank you for your question! The frame and the maintop is one part and cannot be purcahase separately. The part number is 316456236 for the MSRP of $228.46. Most parts can be purcahsed directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor).
SOURCE: Lifting the glass top to replace elements
I removed 2 screws under the front edge when you open the oven door
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
SOURCE: ge glasstop oven
Check the element connections for good tight connections in both connectors. If ok, swap the element with one of the same size working elements and see if the swapped element works. If it does, replace the element. If it doesn't, the control switch or switch connections are the problem.
SOURCE: Glasstop heating coil replacement
To remove the top,open the oven door and the screws for the top are located on the top of the door opening,remove the screws and the top will open,then you will see 2 screws that hold each element in place,just remove the one not working.
If you have a VESC model you have to order a new glass top. They come glass in frame. My advice as a Viking Certified Servicer is to contact a local servicer to repair your range.
