When i try to burn a cd on my laptop it tells me that an error occured but when i click for error details it doesnt give me any. it will not let me burn any cd at all
I have the same problem with the burner Asus supplied with my laptop. Uninstall it and try this free burner: http://cdburnerxp.se/
It works like charm.
Have fun!
Dan
Try testing the CD first. There are reports that this error will occur but still produce a functional CD.
Next try reducing the write speed, this will fix the problem in some cases.
Next try burning with CD with a different program like Nero. iTunes appears to be a problematic application for this error.
It is possible that the CD burner is near the end of it's life.
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
try to burn at a slower speed, turn off the screen saver and virus scanner? if these try to run while a burn is going it can cause an error, try to defrag the hardrive if needed before the burn, try another brand of media , check for software updates on the burning software
first off go to system information and find details of cd drive and write them down.
next click start,right click my computer,select properties,click hardware,click device manager.locate cd drive and delete.close all windows and restart.on restart system will detect new device and reinstall and more importly reconfigure.this should do the trick
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed.
Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration.
This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'.
Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?.
With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error.
Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring.
A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems.
If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector.
If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Hi there.
What burning software are you using?
