YOU NEED TO FORMAT YOUR PHONE NOT MEMORY CARD.FORMATTING THE PHONE WILL SOLVE YOUR PROBLEM.AND TO AVOID PROBLEM IN FUTURE INSTALL APPLICATIONMANAGER ON YOUR PHONE AND WHENEVER YOUR PHONE SAY MEMORY FULL JUST USE THIS SOFTWARE TO COMPRESS MEMORY.
THERE ARE TWO METHOD TO DO FORMAT NOKIA HANDSET.
MANUALLY.
OPEN MENU>SETTING>PHONE SETTING>FACTORY SETTING.
PRESS O.K. A MENU WILL POP UP LIKE YOU LAST ALL YOUR DATA PRESS O.K.
IT WILL ASK FOR CODE ENTER CODE( DEFAULT CODE IS 12345).
PRESS OK IT WILL DO FORMAT YOUR PHONE.
2. USING CODE.
DIAL *#7370# ON MAIN SCREEN.
A MENU WILL POP UP LIKE FORMATTING PHONE.
PRESS OK IT WILL ASK FOR CODE ENTER 12345 AND PRESS OK
IT WILL DO FORMAT FOR YOU.
3.METHOD NO.3(FOR S60 SERIES MOBILE)
SWITCH OFF YOUR PHONE.
WHILE SWITCHING ON PRESS THREE BUTTON AT THE SAME TIME.(1.GREEN DIALING KEY 2.*KEY,3 KEYPAD NO. 3 KEY) WITH POWER ON BUTTON.
A MESSAGE WILL POP UP LIKE FORMATTING. HOLD BUTTON FOR 3 SECONDS AND RELEASE THEM AFTER THAT.
YOUR PHONE WILL RESTART AND ALL YOUR DATA WILL BE GONE
Problem solved! Turns out that my son didn't realize that you have to call your voicemail box and delete voice messages by pressing "7" on the keypad. He thought that when you pressed "erase all" on the text message menu it erased voice mail, too. So the mailbox was full, as it only holds twenty messages. Sometimes the most obvious solution is the solution!
Are you able to get into the software to purge the voice records?
If not, it sounds like the phone needs to be "reflashed" at an authorized service centre. Take it where you bought it. It should not cost you if it is less than one year old (warranty).
press and hold the voice recording button (located on the right side of flip up part of screen) the list of recorded things will appear after message that voice is saved, when list appears click Options (left button with - on it located on top of keyboard) and than scroll down and select Delete All than press OK button (located in the middle of cursor buttons)
That is really some good problem i also suffered from it what i did to get rid of the problem was that i turned off my phone took out the memory card . Then i restarted the phone and again turned it off and then put the memory card and turned the phone on again and then i saw that phone was working properly might this work for you.
I think your phone needs to get reflashed, but thats an extreme step. First, do a MASTER CLEAR or MASTER RESET or RESTORE FACTORY DEFAULTS. After that, if it still doesnt work get it checked out. The keypad may need replacing or the phone needs to be reflashed. Hope this helps.
you will need to take this to a professional but the problem is either a disconnected cable or somehow the firmware for the keypad got damaged and needs to be put back on the phone.
Key pad problem
