SOURCE: my xerox workcentre pe 220 machine have an error message on "low heat error"
You will have to replace the fuser.
SOURCE: how to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
- hy hru ?
- my 3535 machine problem for a i you give pws diagnostic tool version 3.10
