Machine wont turn on, just displays error message, Shutdown refer to manual.
If I remove power and plug back in, when i turn it back on it sometimes starts for a few seconds and then stops with error message again.
Thanks in advance for any help.
model number
vm0116a
This may be solved by replacing the magnetic brushes. See: http://vitamixrepair.blogspot.com
Sounds like you need to send your blender in to be serviced. It most likely is burned out-- hopefully your blender is less than 7 years old!
The incomparable Vita-Mix 7-Year Limited Warranty will keep your machine
running like-new for seven full years from the date of purchase. If
your Vita-Mix machine is currently under warranty and you require service,
simply call the Customer Service Department at 1-800-848-2649 for
assistance.
I had he same problem. In some cases the magnetic brushes on the blender wear down. You can replace these burshes for as little as $15. I found the parts supplier in Northern California but fogot their name.
Home this helps
