20 Most Recent Vitamix 5000 Work Top Blender Questions & Answers
check my viideo on vitamix sprocket repare https://youtu.be/Dq-kDO6H6N4?list=PLHtEamyrXElkiax86_fZYWR5UmgmevL2_
Vitamix 5000... | Answered on May 02, 2019
It will probably just need the pot replacing, take note of where the wires go. I see someone else here is doing the same job and wants to know where to put them back. Take a photo first saves a lot of grief. The pot is the rotary resistance switch behind the knob.
Vitamix 5000... | Answered on Mar 01, 2019
10 Best Vitamix Blender Reviews
If you ask which Best Vitamix model is the finest this year, certainly I would recommend going through this guide to know about which Best Vitamix blender are actually market leaders. More to follow ...
10 Best Vitamix Blender, see Reviews every single Vitamix Vitamix 5200, Vitamix 7500, Vitamix 5300, Vitamix 750, Vitamix 5000, Vitamix 6300 Vitamix 6500, Vitamix 780, Vitamix E310, Vitamix S55, Vitamix Professional Series 750,
Read more Vitamix Vs Other Brend Comparison Blendtec vs Vitamix, Vitamix vs Ninja, Vitamix vs Nutribullet.
Also See Comparison Vitamix 5200 vs 5300, Vitamix 5300 vs 7500, Vitamix 5200 vs 7500, Vitamix 7500 vs 750, Vitamix 6500 vs 7500, Vitamix 5300 vs 6500,
If you want to Read Best Blender Reviews you can visit The Electric Blender Website.
Vitamix 5000... | Answered on Aug 26, 2018
Check here for replacement of necessary part to be replaced.
Fairly easy to do. You can find a video on how to replace a vitamix potentiometer or Pot for short, check youtube.
Vitamix 5000... | Answered on Jun 15, 2018
motor problem ( brushes worn out or armature damage)
junk it and get a new one as parts if available and repair costs will exceed the price of a new unit
Vitamix 5000... | Answered on Apr 27, 2017
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Vitamix 5000... | Answered on Oct 17, 2015
Have a look at this, this guy has done the job.
http://uppityairlinepilot.blogspot.co.nz/2012/09/vita-mix-5000-variable-speed-fix.html
Vitamix 5000... | Answered on May 20, 2015
Can't find a wiring diagram but I do have a 34mb video showing a motor being replaced. If you want a copy email me at screaming_skull@hotmail.com I haven't searched You Tube, you may find something there.
Vitamix 5000... | Answered on Mar 16, 2015
Bad variable switch?
check out their site, they are awesome, and may help better.
Contact Us Customer Service Vitamix
It very likely needs a new pot switch. That is the rotary one that varies the speed. Purchase through your local Vitamix service agent in your country.
Vitamix 5000... | Answered on Nov 30, 2014
Check the hi low switch, it may be faulty.
Vitamix 5000... | Answered on Aug 12, 2014
You need to pay more money and buy the better model to get the speed control.
Vitamix 5000... | Answered on Jul 19, 2014
Hi - another thing that may be helpful is to watch the You tube video about this issue. I saw it today and it may be helpful. There's a little wrench that goes with it I remember.
Vitamix 5000... | Answered on Jul 14, 2014
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Vitamix 5000... | Answered on Mar 11, 2014
Vitamix 5000 Work Top Blender Logo
95 questions posted
Top Vitamix Blenders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
View Most Popular
Vitamix Blenders
  • Vitamix Blenders
Most Popular Question
replaced variable speed switch now seems
  • Blenders
