Question about Vitamix TurboBlend 4500 Work Top Blender
Vita-mix Blender will not power on
While blending dates, coconut & slivered almonds, the blender stopped working?? Sounded as though it lost power.
Posted by ebmplanner on
Anonymous
We just had this problem.  Called VitaMix and they talked about resetting the thermal protection switch inside.  They suggested lifting the base down firmly, but gently, on the counter to help the internal switch reset.  I did it while they were on the phone and, sure enough, the machine came back to life.  Hope this helps.
Posted on May 07, 2009
nan oswald
    New Friend:
Worked! Placing the base firmly on the counter made the motor run again. Whew!
Posted on Jul 01, 2012
  • Devanathan Raghavan Sep 16, 2013
    Worked for me too! What a blessing this whole internet is :)
Jeff Merrill
    New Friend:
My vitamix vitaprep 3 would power on (power switch was lighted up blue), but not run. I opened it and found one of the two white wires had jiggled off of it's connector, and was dangling against a metal heat sink. Plugging it in fixed the problem. Note that when disassembling, you need a 5/64 inch Allen wrench to remove the top sprocket piece, and that the Allen wrench nut is positioned such that the wrench has to be inserted about 20 degrees up from perpendicular. This wire jiggled loose after about 3 months of daily use.
Posted on Jan 01, 2018
Anonymous
I turn on my vitamix and there is no power
Help
Posted on Aug 09, 2009
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
Need a vitamix VM0115A MANUAL
http://kitchen.manualsonline.com/support/vitamix/blender/manual-for-vitamix-vm0115a-5036806
Apr 12, 2015 | Juicers
My blender goes on and off
I think your best bet with a machine like yours is to contact customer service.
Check here:
Contact Us Customer Service Vitamix
Mar 12, 2015 | Vitamix Vita-Mix Blending Station Advance...
The buttons on my vita-mix vm0115e wont work. We have been loosing one button at a time. Was going to see if there was a loose cable or something, but I can figure out how to get the base off.
WE do not have your model here in NZ but this is how you get into our models
Remove square rubber base beaker locates onto. Remove motor driving clutch. Remove 4 screws under rubber pad you have just taken off.
Mar 28, 2014 | Vitamix Vita-Mix VM0115E 36021 Blending...
Diagram of 06 jeep grand cherokke blend doors
Asking about a Jeep Grand Cherokee in the kitchen blender department will probably not get you the information you need.
Jul 25, 2013 | Vitamix Vita-Mix 18007 Door Cover for...
After blending cake batter the blender became hot and it's not working what shall I do
You have burnt up the machine. It will no longer function and would be unsafe to try further. Replace it.
Jun 03, 2017 | Philips HR1350 SingleSpeed Handheld...
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
My blendtec blender is displaying the message watchdog timeout why ? please help
I had the same problem with the Watchdog reading and I simply turned the On Off Switch really fast and Presto! It worked!
Oct 04, 2010 | Blendtec Extra Carafe / Jar for the Total...
Seems like motor has lost power
This sounds like the black rubber coupler has broken. The teeth often get knocked off. Have a look at the part shown in hte pictures here:
http://kitchenaidblenders.co.uk/Home/tabid/36/p/Two-%282%29-KitchenAid-Blender-Coupler-%2b-WS-Fitting-Tool-9704230_2plusWS/ProductID/175/Default.aspx
Jan 22, 2010 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Vitamix TurboBlend 4500 Work Top Blender Logo
9,332 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Ross Keen
Lawrence Oravetz
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
