My remote has broken for the toppro tpr5000 PVR and I need to replace it. Can I purchase a universal remote for this product or should I just replace the actual remote?
Check the site linked below. It has setup code lists, and setup proceedings to many popular brand remote controls. Refer them and see which brand remote control have setup codes to your device, and buy that one. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to
many popular brand remote controls are given.
Three digit, four digit, five digits and two-digit code list are
there. Check the site with
patience. Surely you'll get a solution
to your problem. Search the site by
'Timeslide' option. It will make search
easy.
Visit this site too.
SOURCE: harmony 890 remote
I finally found a user manual on line at www.http://www.smarthome.com/manuals/80652.pdf
It's 19 pages long and contains lots of information that I found helpful.
mshllb
SOURCE: Giant Omnitech remote codes
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Harmony 550 remote does not
I had a similar problem setting up the 550 today. The problem was caused by the delay time needed by the TV before it was "ready" to receive new commands. I have a Vizio LCD. The problem was solved using the Harmony software for troubleshooting the TV device. I selected "does not change input on startup" or some such similar wording. It then allowed me to change the delay time. I extended the time to 7500ms and it would then change channels. I also changed the sequence of startup for devices to start the DVD and ReplayTV second (after the TV) to give the TV more time to boot up (or whatever it really is doing).
You can also add additional commands to insert a delay and then re-issue the input selection. However, I don't remember the sequence of steps that got me to that screen. Good luck.
SOURCE: need a code for an
Aveis is a daytek product which is a Daewoo company. I found a site where you can check and make sure of this http://www.daytek.ca/ Click on products. I found codes for daewoo on page 35 of a manual I downloaded from this site:http: //tv.manualsonline.com/manuals/mfg/shaw/atlas_pvr_universal_remote_control.html . I hope this works for you.
