Ordered a new handle release pedal for my vax power 6 U90-P6-B hoover but it arrived with no fitting instructions...how do I replace the new part.
SOURCE: Hoover Handle Release Pedal Replacement--How is it possible?
If you look at the picture, the slots are right across from the drive wheels, you can see the slots in the picture. Use a flat blade screwdriver.
SOURCE: Handle foot pedal release U6425-900
If you look under the vacuum where the latch is located, it is held in place by tabs on either side of the latch. The latch had a pin that holds it in place. You need to insert a small flat blade screwdriver to bend these latches back carefully to release the pins. Once the pins are freed, the latch can be pulled out the top. The replacement should be installed in the same orientation by pushing in from the top until the pins on the latch snap into place.
SOURCE: Bissel 3593Handle Release Lever/Pedall replacement
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
SOURCE: How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
the handle is broken
