A modern GT710 is a PCIE card and from what I can find out the 945 board only has a single PCI slot. They would not work. You would have to find an old PCI graphics card somewhere.
Please remove and re insert your SD card. Make sure it fit perfectly ob card slot.
Then check the memory status on your phone.
If still unreadable please use another good card to test on your phone to know the root cause.
Still unreadable? The problem is on your phone
Sometimes the interface between card and board get problem due to factory defect or misuse of card.
In this case you need dissemble the phone to see the problem and get it repaired.
Yes, but the camera has only 32M of internal memory so you won't be able to take and store more than a handful of pictures. For "real" use you'll need one or more SD cards. Make sure you get SD cards 2GB and smaller, not SDHC cards.
this will not work. The HP 945 does not support 4GB cards. 4GB (or more) are SD-HC (High Capacity). This is new format which only will be supported by newer camera models.
You will need to provide the sound card you are using, or the model of the computer (if retail) to get the sound card drivers.
Here are 945 drivers though: http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2115&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
There are 3 methods to format the phone
IMPORTANT: back up your phone and memory card first!
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore.
note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area.
Nokia Code : *#7370# : NOKIA Format phone (Soft Reset) Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset) Found these in the N95USERS fourm.
Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button
While holding this combination press the power button once to start the phone
Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable.
Then select Mass Storage mode on the phone.
Once you PC has installed the Mass Storage device you can format the card from My Computer.
Note: assuming Microsoft Windows XP or VISTA.
Billman87
