Keurig B60 Coffee Maker Logo
Joyce Schneider Posted on Apr 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to program the brew size?
Need assistance programing the brew size? thank you
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Jan 30, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
819223
Points
6396
Select TWO CUP for most all cups as this works best.
1 Related Answer
Anonymous
  • Posted on Dec 27, 2009
SOURCE: Keurig Platinum Program Problems
I called Keurig support and I was told that the brew size would not display on the LCD as the manual instructed. They said it was a misprint.
Hi. My new tchibo coffee maker won't brew the large sized coffee, instead only giving me about a tablespoon in my cup. The other sizes work fine. Suggestions? Thanks in advance.
Hi there! I'm sorry to hear that your Tchibo coffee maker is not brewing the large size coffee properly. Here are a few suggestions that might help:
  1. Check the water level in the water tank. If the water level is too low, the machine may not be able to brew the large size coffee.
  2. Make sure that the coffee filter is properly inserted into the filter holder. If the filter is not inserted properly, the machine may not be able to brew the large size coffee.
  3. Clean the coffee maker. The coffee maker may be clogged, which can prevent it from brewing the large size coffee properly. You can clean the coffee maker with a mild detergent and water.
  4. Descale the coffee maker. If the coffee maker is not descaled regularly, it can build up calcium deposits, which can prevent it from brewing the large size coffee properly. You can descale the coffee maker with a descaling solution.
If you have checked all of these things and the large size coffee is still not brewing properly, then you may need to contact Tchibo customer support for further assistance.
Here are some additional tips that might help:
  • Use fresh, cold water. Stale or warm water can affect the taste of the coffee.
  • Use a good quality coffee. Cheap coffee beans can make the coffee taste bitter.
  • Grind the coffee beans to a medium-coarse grind. A too fine grind can make the coffee taste bitter, while a too coarse grind can make the coffee taste weak.
  • Clean the coffee maker regularly. A dirty coffee maker can make the coffee taste bitter.
I hope these suggestions help!
When I press the espresso button instead of esspreso makes a long coffe .I must ad I descaled it yesterday .
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Adjust bunn coffee maker water level
To adjust the brew volume/batch size you will need to access the main circuit board behind the front panel. Isolate the machine before removing panels.
NOTE: Check that the brewer is connected to water supply, the tank is properly filled and a funnel and server or decanters are in place prior to setting or modifying batch sizes.
  1. Modifying batch sizes: To modify a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. If the brewer has a batch selector switch, position it to the size to be changed. To increase a batch size: Press and hold the START or BREW switch until three clicks are heard. Release the switch (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory) and press it again one or more times. Each time the switch is pressed, 2 secs are added to the brew time period. Allow the brew cycle to finish in order to verify that the desired volume has been achieved. To decrease a batch size: Press and release the START or BREW switch once for every 2 sec interval to be removed from the total brew time period; then immediately press and hold down the START or BREW switch until three clicks are heard. Release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). Allow the brew cycle to finish in order to verify that the desired volume has been achieved.
  2. Setting batch sizes: To set a batch volume, first check that the SET/LOCK switch is in the "SET" position on the circuit board. Press and hold the START or BREW switch until three clicks are heard (this will take approx. 10 secs) and then release the switch. (Failure to release the switch within 2 secs after the third click causes the volume setting to be aborted and previous volume setting will remain in memory). View the level of the liquid being dispensed. When the desired level is reached, turn the ON/OFF switch to "OFF". The brewer remembers this volume and will continue to brew batches of this size until the volume setting procedure is repeated. Empty server(s), turn selector switch to positions that have yet to be set and repeat batch setting procedure until all batch sizes are set.
    NOTE: When brewing coffee, batch volumes will decrease due to absorption by the coffee grounds.
  3. Setting programming disable feature: If it becomes necessary to prevent anyone from changing brew times once
    programmed, you can set the SET/LOCK switch to the "LOCK" position. This will prevent any programming to be done.
    NOTE: If the clicks cannot be heard, lightly grip the incoming water line to feel when the valve cycles on and off.
My Incanto Sirius coffee maker is acting strange. It automatically keeps brewing (1) large coffee. The only way to stop this is to shut off the machine. I am getting a LCD read out of Program quantity....
Program quantity is trying to program that amount.
When it starts to brew and gets to the quantity you want for that cup size push the brew button again and see if it stops.
I have the Cuisinart Auto Grind & Brew and don't know how to program to brew stronger coffee...manual lost. Can you provide assistance? I've tried to download manual but can't.
The only way to adjust strength of coffee on the Grind&Brew is by changing how much water you use. The container for the beans only holds enough for 10 cups of coffee.
Cannot program the machine....
Hi
To program the machine for brew quantity, Just hold the button down the whole time,(do not release) As it is dispensing liquid, when you get to the desired quantity, release the button. You can do this for each cup size.
Need assistance on how to program the timer for my cuisanart 12 cup coffee maker
1. Set the desired Brew-Start time.
a. Turn the FUNCTION KNOB to “Prog”.
b. Set the time you want coffee to begin
brewing by using the minute and hour
push-buttons. Follow the same instructions
you used to set the time of day, in
the To set the time section above.
2. Turn the FUNCTION knob to the “Auto On”
position. LCD will display the current time.
3. Lift and release the FLIP SWITCH. The
green indicator light will come on to remind
you that the programming function is in use.
At the programmed time, the red light will
come on as well, indicating that the brew
cycle is starting. Both lights will go off when
keep warm cycle ends.
NOTE: To reactivate the auto-on feature to
start brew cycle at the same time another day,
simply lift and release the FLIP SWITCH. The
green “auto-on” light will illuminate.
The manual can be found here:
http://www.cuisinart.com/share/man/25_man.pdf
1helpful
Saeco Royal Digital Not brewing Coffee
If you try to make a cup of coffee, hold the button to see if there will comes some coffee, it can be the memory that have loose the settings. If so you have to program the machine again.
Best regards
/Mirran
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
