20 Most Recent Gaggia Brera Coffee Maker Questions & Answers
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Gaggia Brera... | Answered on Feb 14, 2017
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Gaggia Brera... | Answered on Mar 07, 2016
You have to reset this manually after descaling. This is done by pressing the bean selector button for 6 seconds.
Gaggia Brera... | Answered on Mar 05, 2016
Carefully check soldered joints and re solder any suspect cracked,cold, bad joints.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Gaggia Brera... | Answered on Mar 01, 2016
You may have accidentally changed the amount setting for your espresso shot when resetting the descale counter.
If you lost the manual you can find one here.
http://www.gaggia-usa.com/support_docs/Gaggia_Brera_Quickstart_Guide.pdf
On page 11 (with the printed number 31) you find how to change these settings:
• Place a cup under the dispensing spout.
• Hold the "espresso size" button pressed for 5 seconds to enter the programming mode; the "coffee" icon will blink quickly and the coffee will start to be brewed; the icon will flash during the whole coffee brewing cycle.
• Press the same "espresso size" button again when the amount of coffee in the cup reaches the desired level.
At this point the button "espresso size" is programmed; each time it is pressed and released, the machine will brew the same amount of coffee that was just programmed.
The same operation can be repeated for the "Lungo size" button.
Gaggia Brera... | Answered on Jun 15, 2015
try to hold the steam/hotwater button for 5-6 seconds.
Gaggia Brera... | Answered on Sep 13, 2014
Gaggia Brera Coffee Maker Logo
69 questions posted
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Gaggia Coffee Makers & Espresso...
  • Gaggia Coffee Makers & Espresso...
Most Popular Question
stripped tested grinder all ok no
  • Coffee Makers & Espresso Machines
