20 Most Recent Saeco Royal Digital Plus Coffee Maker/Espresso Machine Questions & Answers
After a tons of browsing and debugging finally I got the real solution to my similar problem with a Saeco Minuto HD8763 coffee machine: the root cause was a bad hall sensor and a weak magnet at the grinder toothwheel (the left magnet whcih was removed from it's original place). The upper one was okay and down under there is the replacement magnet which I made from a piece of HDD neodymium magnet and glued to fix it.
The original hall sensor was marked as "210k 3491" ("HAL506K" based on some other service manuals) and the new one was a cheap non-smd but same size, unipolar "TLE4905" type.
Saeco Royal... | Answered on Jul 07, 2019
Hi again,
here is how to get ride ofCoffee Dispenser Blocked issue. the reason for this error to come inthe screen is because the machine has reached the counter lockingnumbers of coffee. which is stored in the machines memory.
firstwith the machine switch on and Coffee Dispenser Blocked on screenpress menu button, than arrow up or down until you see VENDING onscreen and the courser flashing next to it press ENTER once. than u cCODE on screen DO NOT press ENTER yet, press arrow up or down untilLOCKING COUNTER on screen ( you need to increase this number) bypressing ENTER you will be asked to enter CODE the default is 0000press ENTER button 4 times than u will go back to LOCKING COUNTERpress ENTER again here u will c the last digit on the right isflashing by pressing and hold down arrow up u will increase thisnumber. keep pressing until 20000 or more it is up to u. when youselect what ever number u want press ENTER once again. than ESCbutton to exit the menu. Switch the machine off than on and u will beable to use your machine again. if u have any problem please sendyour phone # and I'm willing to call you to go throw it with u in thephone.
cheers
Saeco Royal... | Answered on Feb 05, 2019
I think your brew unit is moving very slowly?
If is lke this ,you have a problm with the board.There is a TIP33 wich is defectiv. Change it with new one.
Saeco Royal... | Answered on Jan 14, 2018
Try to cantact Saeco Australia ( www.saeco.au), or Saeco Italy (www.saeco.it).
They should know where you can get spare parts.
Best regards
/Mirran
Saeco Royal... | Answered on Oct 29, 2017
The dispenser is the brew unit in the back of the machine above the drain tray, open door and remove the black unit within and check the screen above the red o-ring.
Saeco Royal... | Answered on Jul 28, 2017
If the pump is only getting 50v of power, then the power board may have a bad resistor and the board will need to be replaced. This is an older machine, so it may be hard to find a new one. Refurbs are never a good idea, so you may end up purchasing a new machine in this case.
Saeco Royal... | Answered on May 19, 2016
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Saeco Royal... | Answered on Feb 24, 2016
Possibly an electronic problem. My did something similar. Need tech to replace appropriat part then sell it and get a msnusl machine.
Saeco Royal... | Answered on Sep 15, 2014
Hi If you make a pre-ground shot but don't put any coffee in it, and it does the same thing you have a blockage in the brew head. If it run normally, your grind is to fine. Push the grinder lever to a larger number. It takes 3 times to change to the new grind. If it still dribbles, remove the brew unit (behind the door) Holding the handle, the top left side is the brew head. There is an outlet pipe that exits the backside towards the machine (looks like an "L" pipe). 2screws hold it to the top. Remove the 2 screws while holding the manifold ("L" pipe assembly). Once they are removed, lift the l assembly off (becareful, there is an O-ring, spring and inside a crystal ball (don't loose it or your out of luck). Turn the brew unit upside down while holding the brew head in your other hand and the crystal ball should fall out. If it doesn't come out put a towel down and tap the brew unit on the towel. This should force it out. Now remove the brew screen, by holding the screen with your finger and twisting the thumbscrew (remember thumbscrew, DON'T use the key to install the screen, use your fingers..... Once the screen is out look at where the screen was. There are 2 holes. 1 big one in the center and a small one to the side. With the brew unit upside down over the towel insert a paperclip into the small hole and force anything out the other side. I have gotten worms almost a 1" long from this passage. The paper clip has to go from this side to prevent damage to the seat on the other side. Clean then reassemble. Brew unit on towel right side up. Drop the crystal ball in first. Then the spring small end first on the crystal ba Now the O-ring over the spring, then place the manifold on top of that with the pipe towards the machine. Insert your screws (I turn them backwards a little with a little downward pressure until they feel like they drop into the threads. They should turn down easily, if not back them up a little more ( we are trying to find the old threads) and tighten. Install screen, and tighten with your fingers. The screen just needs to be flush with the bottom of the brew head. Run another pre-ground without the coffee and rinse it out. Do this once in a while to prevent this.
Saeco Royal... | Answered on Jun 07, 2014
hi my name is Lee Davidian here is your answer
Automatic Decalcifying Cycle
The automatic decalcifying cycle keeps the machine in perfect operating order. When prompted by the user, mineral buildups in the internal boiler can be dissolved and removed with Saeco’s decalcifying solution and a push of a button.
Saeco Royal... | Answered on May 23, 2014
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Saeco Royal... | Answered on Mar 28, 2014
hi check that programation is set off on direct water source
thanks
Saeco Royal... | Answered on Mar 23, 2014
O.K.
Saeco Royal... | Answered on Nov 02, 2013
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
169 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
blocked dispenser
  • Coffee Makers & Espresso Machines
