My Toshiba L305 laptop has only a microphone sound card. I want to record music from the internet. Is there an external card that will do this?
You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
SOURCE: Sound Card Problem for Sigma Tel C-Major Card in Dell D600
I am using Dell latitude D530 and sound card not woking sound card is sigma tell.....
SOURCE: how to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
SOURCE: how do i disable my built in microphone?
double click on the sound icon in sys tray to access properties and disable from there or just turn the slider all the way down
SOURCE: Toshiba Satellite L305-S5900. No power indicator light.
sorry there is no fuse that i know of on the satellites it sounds like a motherboard issue see if it can be warranty repaired by the manufacturer
SOURCE: my screen is scrambled don't know if its the
if you can see the windows screen on start up and it looks ok and scambled when on desk top you may fine its needing driver updates,
if the screen is the same scramble at start up as in desktop screen then the lcd panel is at fault ,the videocard in from memory on the motherboard
there are chips along the top of the lcd inside the case,some times they fail and do the same scramble result,replace lcd panel and away you go,
try an external monitor yet?Misterdj
If you are using xp
Go to control panel
Click on sounds and audio devices
click on voice
See voice playback?
click on volume make sure there is not a check mark in mute under microphone
Do the same for voice recording
and check the volume levels on both
Hope this helps
